Password manager
17 May 2013
West Sussex, UK
OK, thinking about using a password manager, but which one is the best? I don't mind paying for it if it's worth it. I need to be able to use it at home on Windows machine, and on Android.
Ta
That article is from the middle of 2015, I have used Lastpass for 5+ years now and never had a single issue (I also pay for it which is $24USD per year).
Stoner81.
Keepass with the keyfile database file (.kdbx) synced using Dropbox. Android app works well too.
Secure, convenient and free :)
*edited following KIA's correction of my bad description/terminology*
Ta
I used KeePass for years, works perfectly.
Relatively recently moved to LastPass though as it integrates nicely in to the browser for autofill plus syncs to my other devices.
Would you say LastPass is better than KeePass? These seem to be the two main choices.
Do you want access to your passwords on other devices or through a web browser? If so, then LastPass all the way.
If you're not bothered about browser integration or access elsewhere, then stick with KeePass.
I started to use lastpass a few months ago. No complaints so far, browser extension is simple, android app seems good and I also use a yubikey for two factor authentication.
Am I right in saying it works in a similar way to the Google Authenticator where it generates a code for you that you need to enter, except with yubikey it'll autofill that code?
Yip pretty much.
But you can also configure it to effectively have a second key that you can use for another programme/use.
I got one that's NFC enabled so can use it with my phone too.
