Not MSI (they aren't the only ones guilty of this). Cleaning and replacing reduced temps by 15C.
what make is your card? I have the sapphire 390 and wonder what my thermal paste is like but my temps seem fine
My Sapphire nitro 390 which is running at 1100/1700 (1040/1500 stock) barely see's the low 70's!
I've always thought MSI to be good quality aswell! Maybe good components but bad quality control.
Sapphire seem to be consistently good, I moved from Sapphire to MSI for a few cards but I'm now back with Sapphire and glad of it.
I have just replaced the thermal paste on my card after reading this thread.
As per pics below, same issue, way too much paste. Temps going into the 90's playing The Witcher 3 and fans spinning at 100%.
Replaced with just a little line of Thermal Grizzly Kryonaut and fired up The Witcher 3.
Max temps 75'C, max fan speed 59%. The best thing about it is the reduction in noise from the fans. Highly recommend anyone with this card to do the same.
Did anyone find out if replacing the thermal paste will void warranty with MSI?
How did you contact them Rensin? I asked them via their website support ages ago and they said no although I'm not sure they understood what I was asking them.
A year after that I got fed up and replaced it anyway and then wished I had done it soon due to the difference it made.
