thanks again tyler_jrb.
Tried the windforce on its own to see what temps we get in my system. Its a much better card than the MSI in terms of OC'ing and cooling with just a slight be more noise from the triple fan setup.
Also did a asic quality check (curiosity sake) and the windforce is 86.3% vs the MSI at 68%.. The MSI would clock to 1470mhz on stock volts, 109/91deg power limit/temp. The windforce on stock volts with same limits will reach 1550mhz without any issues. Not pushed it higher than that but after a good hour gaming temp is under 65degC.
So, windforce is definitely the cooler card and better performing BUT not sure what I'm going to do now. I don't feel like I need to upgrade my system as my 3770k @ 4.5ghz over 3yrs has been solid and more than ample performance for my needs.
Possible options I'm thinking of at the moment.
Try a 1155 socket mobo with extra PCI spacings. S/hand ebay (cheapest option)
AIO cooler on the MSI (would still need PCI spacing as height of H/sink pump would foul lower card)
Sell the MSI 6G and get a second windforce (to use with s/hand 1155 mobo) (extra expense over above with potential for better OC on second windforce)
try a custom loop to cool SLI 980ti's or also include CPU (most expensive option)
Need to have a think but so far new windforce is offering a few extra Frames over my MSI as a single card setup with stable overclocking on both.
