**** The Official Note 5 thread ****
Back to UAE (XSG) firmware with yesterday's MM update:
The security patch level on this is dated March 1st unlike the CAM which was February 1st.
All looking good.
Flashed and is running well. I've flashed the Cambodia rom followed by Iraq followed by this, all without a factory reset. So far, so good, but think will factory reset at some point.
Hi guys ! Am I right in thinking the "C" model of the SGN5 will work with all 4G LTE bands in the UK or just some ?
I really like this phone & hating Samsung for not being it to the UK & instead thinking the S6+ is what we want ! Not....
Funny as I was in EE retail shop & asked a branded Samsung rep why we didn't have the N5, he showed me the SG6+, I politely said you don't have to follow apples footsteps with plus modles & then asked him why Samsung place the Return/back key on the opposite aide to stock or other brand that follow the key being on the left ? He said it was the same & I asked dhim to check again, after he looked at a the phones including my Nexus 5 he didn't have an answer & then replies "You learn something everyday". Hahahahaha
The 'C' model does indeed work on all UK 4G networks.
The "back" or "return" that's on the bottom next to the home or middle one. They are on opposite sides to other brands of mobiles.
It's something I can get use to & by no means a deal breaker, just a shame you can't switch it over as they are part of the moblies structure.
Thanks for the info on the "C" model.
How do people deal with the warranty should anything go wrong ? I know Samsung have a 24 month warranty on it but I guess it's down to the seller's return policy.
But you can swap them around, just install All in One Gestures.
You'd have to send it back to a Samsung centre in the country/region the phone was initially registered to.
