The Division. Are we interested?
Status
Not open for further replies.
Well i got to lvl 6. I have nfi whats going on. I upgraded some wings, i did some missions with some dudes i found by fumbling around the group finder ui. I swap weapons with new weapons with higher dps. I dunno.
Can i sell weapons? I've been deconstructing everything so far.
Unless you're in dire need of credits now, keep deconstructing everything and save the materials for level 30. You'll be able to use them to craft yourself some nice weapons and armour.
In much the same boat mate. I'm lvl 10 and not a clue what I'm doing in regards to getting my stats up! Still having great fun though!!
Yeah I'll have to give it a go and see if its any better
Single GPU here and not a single crash. Not what you want to hear I know but maybe go single GPU for this?
Updated to the 364.51 drivers and using just a single card and it appears to be stable and issue free. Played for about 2 hours without any problems so hopefully it's just an SLI bug with the game. Performance on one card is actually nearly on par with 2 which I was quite surprised at too lol (2x 980 ti superclocks, only difference is the AA mode basically)
**** bucket achieved :D How my loadout now looks:
Now the grind for yellow gear commences......
And yes, don't just go by the colour all the time, a lot of my blues have been better than purples as well as a couple of greens.
Really wish they would fix the stats bug though.
Had an epic time in the dz tonight with haz, tony and copey, we were on a purple loot roll, I had to destroy 5 purples though as my stash was full!
Doesn't look good. You have any overclocking going on? Only happen in the Division?
Yes only the division, no overclocking
That can be attributed to memory being too hot or clocked too high and normally the latter.
Will check temps.
over heating or to much stress to the card. reset the clock speed to default.
It should be default unless it was factory overclocked.
Thanks for the help guys, sorry I should have mentioned in my post-
A) I have the latest drivers.
B) cpu & gpu are both at stock no oc.
C)It only happens looking forward, If I turn round & look behind me everything is fine, I also think that every time it has happened its been on a mission.
D) Tried taking a screenie but it turned out as just a black picture.
Its just a damn pain when trying to aim at mobs & textures get all stretched in front of them. As I said its a pretty rare occurence tho, & I think one time I just relogged & it went away, will have to check that again next time.
Will check temps.
Pretty sure it will be your gpu memory. You can have the issue at stock clocks if the card is faulty/failing.
Nice Nexus ;D
Shall I show you what kind of numbers you're aiming for? Still plenty of room for improvement on my stats though...
And I drawed you a smiley face!
Well,got some high end gear dropped,M60 and some mods.
Made Damascus - not sure it can be called high end - my blue pistol does way more damage,and other stats are better as well,you can put more mods on it.
DZ rank now 36,need to get to 50 so i can start buying blueprints for high end's,long grind
got to L21 DZ today and L20 in game, got some good gear and starting to understand the interface screen more. DPS is calculated a bit odd in fact my top tip would be go by the actual damage number of the gun you might be upgrading to
Yup. Go by Damage and RPM to get a rough idea of your dps, then factor in any Talents the guns have. I've found the Accuracy stat and magazine size hugely affect the shown DPS figure -- and they don't really translate into actual DPS like that..
Level 39 in the DZ now, hoping to hit 50 before the weekend :)
I have had in total only a single Gold drop compared to a friend of mine who gets about 1:20 !!
Still getting really crap drops on daily. Going to have to go into the dark zone I think. I got to level 12 pretty much on my own but would love to join a group when I'm off on Thursday and Friday if anyone is up for it?
Just finished upgrading my wings & still 2 zones to do, level 29 too, got to hit DZ for a while before I go for 30 tho, try & rank up a bit, only 20DZ atm.
Status
