- 14 Dec 2013
Finally update has come through. Gone from G935FXXU1APAW to G935FXXU1APC8. Not sure why it took so long to show up on my device though?
Does anyone elses first few % drop quickly? I'm used to my Nexus 6p hanging to 100% for a lot longer!
unplugged mine at half 6. battery is currently on 96%
Have you been using it? It's fine when not in use, just the first minutes of use it drains quickly.
Got the S7 flat and enjoying the device but have noticed the fingerprint reader has roughly a 50% failure rate. I've added both thumbs twice, I'll try adding the same finger four times to see if it improves.
hmm. mine generally works first time, everytime.
Low light just is pretty damn good on this no? The above pic was taken with only a candle burning 6 feet away. At 1/4s (iso1250) the auto mode has captured slightly more detail than what was visible with my eye. I used touch focus to focus on the text. The Nexus 6P is great, but it would not have been able to lock focus quickly (if at all) in this kind of situation.
Sure there's some grain, but given the conditions that is otherwise a usable image!
tbh I think MBKHD messed up his review with the low light comparison!
Just added the same fingerprint four times and it's working every time now.
Did you move your thumb a lot when adding the print to make sure it has your print from all angles? I did that for both thumbs and 2 fingers and it works 99% of the time.
I did move the thumb slightly, but as it's flawless now with one thumb I'll keep it as it is.
