- 25 Nov 2011
- The KOP
Farcry primal 970 vs 390
Well done AMD, although I did see at least one discrepancy in the test. They seem to have been carried out at a different time of day (in-game), and the Nvidia card is having to reproduce more shadows (on grass, leaves, and ground) than the AMD because of this. You can see an example of this by pausing at 1:26 and at 2:17-18 in the video. I'm not saying the AMD still wouldn't win, as this may not be an issue for most of the video, only in some parts, but it's there.
Something different this time. CPU test with 6700K, vs 5820K vs 5960X.
Results clearly shows that Skylake with it's improved IPC is the winner in DX11 tittles even under SLI. Still waiting to see proper DX12 benches.
Its not that much of a win though for the most part - a lot of the time there is barely a whisker in it aside from FC4 where the overclocked Skylake steps ahead - also be wary comparing the framerates at the top right hand corner as they are at times slightly out of sync with what scene each CPU is displaying - if you use the graph as a guide to when they are showing the same thing the difference in performance at some points is much less than the difference in the numbers at the top.
I'd be worried if the 390 wasn't winning.
They might be around the same price but the 390 is a newer and technically more capable card.
Considering the consoles use more cores I'm surprised more games aren't being optimised to make use of 4+ cores
Wow, another nice win for AMD there! Hopefully it's just a driver issue with the nVidia lineup![]()
I will say though excellent work from amd release drivers etc showing again there leading the way in DirectX12.
providing an objective frame rate of 45 FPS for frame rates 59 FPS to 45, 30 FPS for frame rates 44 FPS to 30 FPS, and so on.
While the 390 is the faster card running that game - there is a problem there with VSync where the 970 is just missing the multiplier and the 390 is just hitting it - resulting in a massive but artificial performance differential...
GG Microsoft.
EDIT: To go into a bit more detail:
This means that the 390 could be capable of say 45fps and the 970 44fps but one will output 45fps and the other 30fps - notice how in the video the framerates are very consistently sitting around 30fps for the 970 and 45fps for the 390 - with a little drift due to the fact that the framerate readout is sampled from an average over 1 (or more depending on the particular implementation) seconds. Which is due to the horrid MS store implementation not an AMD or nVidia thing.
Though the crashing drivers is entirely on nVidia.
EDIT2: Oh and there is a 50fps cap in the game wow! not in a position to watch the video in its entirety atm so some of that might be covered in the video.
There is more to it than that. I get your point though but the gtx970 is struggling to hold 30fps at points never mind 45.
