Actually a better response would have been ....
' Why didn't you point it out to me earlier !!! '![]()
I mentioned it on the previous page.
Just noticed AMD now allow you to fine tune overclocks for monitors, wondering if anyone knows what settings to use to try and achieve 75HZ on my LG 29um65?
I believe some have been able to get 75HZ without frame skipping on nvidia systems
Any ideas on where to start?
Yeah wouldn't do any harm trying it I imagine, thanks.
I have tried CRU before and messing with a couple of settings but always got frame skipping with anything above 60HZ![]()
AMD doesn't support 21.9 VSR.
I have the Acer X34 75Hz 3440x1440 Freesync monitor and the MSI R9 Fury X. Thought I'd share some of the FPS scores I get for games with everything maxed:
Rise of the Tomb Raider (antistropic x4, HXAA antiailsing) - 50FPS
Fallout 4 - 38 FPS
Shadow of Mordor - 67 FPS
Grid 2 - 61FPS
Just Cause 3 - 59 FPS
Bioshock Infinite - 83 FPS
HITMAN - 57 FPS
Thanks for sharing. Im not surprised about the Fallout 4 considering it have had added gameworks effects since launch. How is your experience with the x34? Thinking primarily of IPS glow and lightbleed.
Certainly making me think twice about a 3440x1440 display especially ones with a 75+HZ refresh rate now! A 30-32" 144HZ 2560x1440 21.9 display will be the sweet spot
IMO, it just isn't worthwhile paying more for higher refresh rate screens if you aren't able to push the FPS to get the "full" benefit from said higher refresh rate unless.... you are happy to put up with the SLI/crossfire issues (which is only going to get worse imo)
Obviously the next lot of GPU's will improve performance over current top end GPUs but with the way most PC games these days are going, they are only getting more and more demanding.
