The Division. Are we interested?
Status
Not open for further replies.
I definitely made sure to buy two items. One by itself is worse for sure.
The supply drops and purples needs to change badly. Either have it something like 20 PC for a successful claim or even a Gear item and it would really kick off at the supply points. As it is now I doubt people will even go for them in a couple of days time unless they up the rewards. Purples are the new blues.
Another 4 runs through PA and 4 more HE vests, none of them any use to me. Might have a few more goes later, hopefully land an M1A, wishful thinking.:D
Still can't get the glitch to work, the amount of times I've tried, I could have just done a full run through.
i tried once and couldn't do it either so gave up on it.
if you want a hand with any runs ill be on tonight from 9pm and by all means feel free to pass me your gear you done need lol :D ill be on at half 8
Gear sets for sure, or some epic weapons :)
I have two pieces of the green gear now. One increased stamina a good amount but decreased firearms, and the other increased firearms but decreased stamina (same set) but together, they increase firearms and stamina overall and both increase electronics.
Because I have two of the same set - scavenging is increased by 100%.
However.....I rerolled both items and changed some stats on them to allow for higher electronics, and higher SMG damage.
One on its own - would have been useless.
EDIT: What I want to get is the striker chest plate with two mod slots as I calculated roughly, I will get around 200-220k DPS and 75-80k stamina with that plus a mod or two. I know DPS doesn't matter, but still, nice to get an increase lol
Will have to talk me through the new gear stuff tonight on Discord.
Sets sound like the way to go, but still curious about how the new greens are better than the yellows?!
I'll be on around 6.45pm onwards.
I'd like to do some DZ, incursion and whatever else people are up for later.
The PA glitch still works, but you have to do it differently now.
Complete the mission once, then deploy your mobile cover (double) in the doorway, somewhere in the middle, so that it is half outside, half inside.
Then run back to the beginning of the mission and re-select difficulty - don't restart so the loading screen appears.
Then just run back to the shield and you should be able to take cover against it and walk straight through the doors.
Cheers I'll try that. The only time I got through this morning was the original way, believe it or not.:D
I wont be on again until after the football, 10pm. But will play for a couple of hours.
Got strikers backpack,those gear sets do wonders :D
Managed to get four of the greens for the damage bonus but it's not working so well for me at the moment. I also accidentally deconstructed one of my purples which gave stamina so have dropped 20k health points and lost one of the talents on my AK47 by not having mod slots on the new green items to keep the electronics stat up.
I'm more than convinced that the scavenging stat is bugged, I now have over 250% scavenging and my drops, div tech crates are still pretty crap. People with less scavenging seem to get more gold div tech than what I do, I have never got 3 gold from one box....
I have 233% and have had nothing better than those with minimal scavenging on. Purples dropping left right and center though but **** purples.
Status
