Caporegime
- 18 Oct 2002
Worth a go imo
Hey chaps, would love your thoughts on this. TBH I'm not doing much more about it except returning - but I still need a monitor so need to know if it's worth bothering with going down the 21:9 freesync 3440 res route? I know that these large panels have been having issues with disconnections when gaming using freesync (the Acer springs to mind). I had hoped to avoid that by getting a newer LG but I've seen that exact issue.
I'm wondering if even though displayport 1.2 is rated to handle this res and hz, it really just struggles to cope if there are any weak links in the chain at all. In essence, it's a bit of a lottery whether it works as designed.
So to start with, my specs:
3770k @ 4.3ghz
16gb RAM
Powercolor r9 390 GPU (previously powering 2 x 24" 1080p monitors via DVI, one of which is a 120hz panel).
So I got an LG 34UC88. Both the Witcher 3 and Rise of the tomb raider are the only games I have tried, but the sound and picture keep cutting out for a few seconds at a time during gameplay when freesync is enabled.
I've tried 3 different branded displayport cables and the issue is exactly the same.
I tried it briefly with freesync off @ 60hz and interestingly did not see the issues. I'm almost certain I would have seen them in even a short space of time as with freesync on, they happen every 10 seconds or so (or more).
I am on crimson drivers 16.4.1
Have re-installed Crimson drivers after using DDU. Have re-installed monitor drivers several times. I have reset the monitor several times. Nothing I have tried has been met with any success when using this monitor with freesync on.
Here is some links to the issue:
I also get this flashing up after each disconnect (you won't see it in the videos as I had disabled the pop up message by that point):
https://dl.dropboxusercontent.com/u/42027960/Ebay/ebay2/20160414_211525.jpg
Do you think I've just been unlucky with my panel and I should get another and try again? Do you think the monitor is most likely to be at fault and not the GPU or 3 different displayport cables I tried?
Thanks, really value your opinions as these sorts of purchases are very expensive and mistakes/faults take up so much time to get sorted!
Burger ... Sorry to hear of this. Seen the video and that really sucks.
You've tried the obvious I take it ? Clean install, drivers etc ?
Must say I didn't buy this monitor for the freesync or gaming but wanted to try freesync '1 day' !
What's the cheapest freesync GPU you can buy ... I fancy testing it myself![]()
I have a 34UM88 (same monitor, flat screen version) arrived today so I'm going to test that later and see if the same issue is apparent.
Also, sorry Subliminal, the UC88 is so much sexier I think, even my wife commented that she far preferred the curve, don't be mad :/
I agree, not mad - could afford it but skimped on it - no regrets really.
Funny you mentioned the Mrs.... Mine too is loving the new monitor - guess it's one of those rare tech purchases that got her approval !
She's on the PC way more than usual too![]()
I've been using an LG 34UM95 happily for the last 20 months. Originally on an Inno 780Ti (which died) and now, for the last 6 months or so, on a KFA2 Infin8 GTX 970. During the last month or so I get random blank screens, which last for a second or two. It's basically switching itself off and on by the looks of it as the power button blinks when the screen returns to normal. Usually once every session I'm on the computer (which can be most days for 3 or 4 hours) when gaming (Arma3 or Elite Dangerous, since they're the only games I play regularly). Totally unsure what the cause is so I'd be grateful for any help.
Monitor, LG 34UM95, is connected by DP
NV drivers are 364.72
KFA2 GTX 970 Infin8 Black Edition
PSU is Superflower platinum 1K fwiw
CPU i5 3570K @4.3
Is it really turning itself off though or just losing the displayport connection?
Is it similar to this:
Why not give the fix that seemed to work for me a try. Probably won't work but I'm sure anything is worth a go. Simply change the preferred color depth in your graphics driver control panel to 6. Not sure where that is in Nvidia land but give it a go, only takes a few seconds.
I have the Acer X34 75Hz 3440x1440 Freesync monitor and the MSI R9 Fury X. Thought I'd share some of the FPS scores I get for games with everything maxed:
Rise of the Tomb Raider (antistropic x4, HXAA antiailsing) - 50FPS
Fallout 4 - 38 FPS
Shadow of Mordor - 67 FPS
Grid 2 - 61FPS
Just Cause 3 - 59 FPS
Bioshock Infinite - 83 FPS
HITMAN - 57 FPS
The strangest thing has happened - I swapped out my i5 6600K for an i7 6700K, installed a Samsung SM951 M.2 NVMe ssd drive - moved Fallout 4 on to it and am now getting an average of circa 70FPS - up from 38FPS before!? There can't that be that big of gain in performance from that change surely? Oddly, before the number refresh rate in the corner of the monitor, which is effectively an FPS counter with freesync, didn't function - I used fraps to measure the FPS of 38. Now though the refresh rate is working in tandom with FRAPS and showing a range of 65 - 75+ FPS! Settings set at ultra both before and after the new install.
Thoughts?
Could be a streaming issue you had before. Ive seen that before first hand.
