15 Apr 2016 at 14:48 #1 Edward78 Edward78 Soldato Joined 19 Oct 2002 Posts 5,780 Anyway to disable or block all the snooping that goes on?
15 Apr 2016 at 15:33 #2 lsg1r lsg1r Soldato Joined 25 Jan 2007 Posts 4,803 Location King's Lynn easiest way is likely something like ultimate windows tweaker 4 It seems to have all the main ones covered.
15 Apr 2016 at 16:56 #3 mmj_uk mmj_uk Caporegime Joined 26 Dec 2003 Posts 25,769 Install Linux? just not using the new Linux on Windows emulator that Microsnoop have developed.
15 Apr 2016 at 17:08 #4 On Holiday On Holiday Soldato Joined 29 Dec 2009 Posts 7,313 They are watching you.
15 Apr 2016 at 17:17 #5 mysticsniper mysticsniper Soldato Joined 1 May 2003 Posts 11,211 Some nice stuff here also http://thehackernews.com/2015/08/windows-10-privacy-spying.html http://thehackernews.com/2015/09/windows10-keylogger-security.html http://thehackernews.com/2015/08/windows-10-update.html
19 Apr 2016 at 05:26 #6 Edward78 Edward78 Soldato OP Joined 19 Oct 2002 Posts 5,780 mysticsniper said: Some nice stuff here also http://thehackernews.com/2015/08/windows-10-privacy-spying.html http://thehackernews.com/2015/09/windows10-keylogger-security.html http://thehackernews.com/2015/08/windows-10-update.html Click to expand... Will zone alarn keep Windows from spying???
19 Apr 2016 at 07:24 #7 Philtor Philtor Soldato Joined 20 Nov 2009 Posts 7,084 Just install and run Spybot Antibeacon. It's free and works a treat.
19 Apr 2016 at 12:44 #8 bledd bledd Don Joined 21 Oct 2002 Posts 46,851 Location Parts Unknown Zone Alarm will break your pc.
19 Apr 2016 at 12:55 #9 abdidas abdidas Associate Joined 26 Jul 2009 Posts 107 I also recommend Spybot Antibeacon, be careful with some of these programs.
21 Apr 2016 at 10:24 #10 nade nade Soldato Joined 6 Dec 2003 Posts 2,717 bledd. said: Zone Alarm will break your pc. Click to expand... Agree with this, if it was 2006 then maybe it was still worth using it, but I certainly wouldn't recommend it anymore.
