Yeah but what for ?
Is there a recent PCIe X1 video card around. Looking to add a basic card to X99 alongside 980Ti SLI but due to M2 SSD my third full PCIe slot is disabled.
Andi.
Yeah but what for ?
You could upgrade your CPU: the 5930 and 5960 - not to mention the Xeons - all have more PCI Express lanes than the 5820.
and possible separate Physx.
I'm not 100% on this but I think you can turn any card into an x1 by removing or covering all sections of the PCI-e slot beyond the x1 terminals. Could physically cut them away or cover them with electrical tape possibly.
not worth it, you wont find any benefit from a PCIE1x GPU for physx. Especially a low card like a GT610
you can disable it in the bios on some boards, pretty sure on my x99 deluxe i can pick 1,4,8,16x from bios options
How many monitors are you running ? (I'm assuming 3 or 4 already)
What makes you assume that.
Andi.
Prime purpose is a second monitor
You can't fit a full connector into a x1 pcie without cutting a slot and that would be tricky I suspect.
Andi.
Well surely you would just run another monitor off your graphics card unless you already have 3 or 4 connected (whichever is the max for Nvidia / the card).
