Thanks, that's re-assuring.
So no bottle-necking from the other older components?
Case: NZXT Phantom Enthusiast USB 3.0 Full Tower Case - Black
What gfx card do you currently have? If you already have a 980 I wouldn't be looking to upgrade.
An OC'd 2500k is still be fine for VR for the most part(cant ever guarantee everything).I'm more worried about potential bottlenecks running VR with my i5 2500k and a 1080 card....either to do PCI speed or something. Been a while so not fully on top of things - but read the 1080 is 256bit bus speed - are the old sandybridge motherboards fully capable when comes to all that?It's bad enough (well mostly annoying) that my usb 3.0 chipset is marked as incompatible with the Oc Rift CV (I had the DK2 on it with no issues)
Probably wants a shiny new 1080
Your overclock is 4.3ghz, so '43' the other poster recommended '40' or 4.0 ghz so in fact your faster. Stop worrying your system is more than enough for even the next gen gpus.
This could well bottleneck your performance!
Don't we all
but unless you have money to burn, you have to consider the performance per £.
And in terms of your USB - is it just the Oculus system test that says it is incompatible? Cuz it's not always entirely accurate. I would go to some place like the Oculus subreddit and ask about your motherboard specifically.
Sorry to hijack the thread but I have an i7 920 (Nehalem) @3.4ghz. I guess the 1080 or 1070 would be overkill.
I've had this CPU for 7 years! It's done me well but I guess I need to upgrade.
Any thoughts?
Overclock it to 4ghz or so or pop a Cheap Xeon in and oc that
https://forums.overclockers.co.uk/showthread.php?t=18618052
