- 7 Feb 2004
Because you should be getting loot from loot from drops not from crafting. So to discourage crafting they've just not put any new blueprints in apart from some odd rotating ones in the dark zone vendors.
Would be fine but if you can't actually get a group for incursion sort of makes it pointless. Tried to get a group, after ten attempts of kicks and glitched starts where you can't enter I gave up.
This then meant i ended up playing destiny again instead which despite playing it through to level 40 for 2 characters on the PS4 i started it again on the Xbox One and I'm still not bored!?
I also rememeber 2 hours i spent in the DZ running from one side to the other between entrances just killing dudes. In the 2 hours i had 1 piece of gear that was worth extracting. 1... My screen was littered with beams of blue, gold, purple and turquoise light for items not worth picking up.
Do i want to risk dying trying to extract a walnut beanie? No thanks Jeff.
