Sorry, I missed your question. I'm using all air cooling now. I was seriously into water many years ago for many years, started when 'state of the art' was car radiators and aquarium / pond pumps.What 360 rads you using doyll? Mine are the older ones that do have a small gap between the fans than needs sealing but it does give you a little more rad space, im getting more like 450cm rather than 300, do yours have big overhangs either end or summat?
Please elaborate. It sounds like you are talking passive case and CPU?
Yeah i think passive is fine for browsing watching movies etc but i wouldnt want it for heavy load as you would be limited.
You can save a bundle and use any of several big air coolers instead of the Nofan CR-95. The only time the CR-95 out-performs big air passively is with big air setting with fins flat .. desk top case design. In a bottom to top Silverstone case with fins vertical they make nice mini-chimneys.Yes. Take a Silverstone FT02 or FT05 case, a Nofan CR-95 CPU cooler, a CPU with a TDP of under 95W and you're good to go. You can get fanless PSUs up to 520W. And the only fan you need is the one on the GPU. You can forget overclocking, of course.
You're missing the point of the CR-95: it's not about processor speed but about noise. Big air fans make noise, and I can tell you that while they may initially seem to be silent, if you're in a quiet room after a time the noise becomes quite audible. The CR-95 doesn't make any noise.
Yes, silence costs. But for some people it's worth it.
I said "only time the CR-95 out-performs big air passively is with big air setting with fins flat" Passively is without fans.You're missing the point of the CR-95: it's not about processor speed but about noise. Big air fans make noise, and I can tell you that while they may initially seem to be silent, if you're in a quiet room after a time the noise becomes quite audible. The CR-95 doesn't make any noise.
Indeed! Big water loop makes huge hole in pocketbook.You can have the best of both with a big water loop, ya just tell all your fans to stay turned off till your GPU reached 50 degrees, the evga PSUs dont turn the fans on untill they reach 50 either, so unless you start gaming you have no fans on, then when you do wanna game ya still have the cooling available. Not cheap also though![]()
HE02 is good. So are Thermalright HR-22, Le Grand Macho and Macho. but even top tier twin towers and flat single towers like PH-TC14PE, NH-D14, Silver Arrrows, Cryorig, etc. The only limitation is the fins need to be in a vertical orientation to create thermal airflow. In the video I posted above (@ 2:54) I think the CPU is under a Thermalrgiht Ultra Extreme and he's running If they are horizontal there is little air movement through the fins. In this case he is using a couple TY-140 fans in the bottom. They idle at about 500rpm PWM on 12v. The newer TY-147A idle at about 300rpm or slightly lower (mine bottom out about 275rpm).I think he meant that any of the big air coolers minus their fans are better VFM than the CR-95.
I use a Heligon HE02 this way.
I guess it depends on definitions. Like what is 'stupid amounts of £££' and 'a little noisy' ? All of my my systems use CPU coolers that cost £35-65.00, cases that cost £60-200.00 new with stock fans and maybe a few added fans costing £4-15.00 each. While one of my systems uses aquaero 5 LT fan controller, all others like yours use motherboard control, some direct header to fan and some using PWM splitters with PSU powr or Phanteks PWM controlled variable voltage hubs costing £6-15.00 each. All of these systems are quieter then ambient noise level 99% of the time, and when under extreme load are still so quiet they do not interfere with radio or TV.I have a mix and match in my machine, it's in a Corsair 400R so it's a small form factor with a lot of hardware to cool down, i tend the let the mobo sort the fans out personally. It can get a little noisey but it's not that bad in the long run, even if you have headphones on - I'd rather things be running perfectly with a bit of noise then hardware clocking themselves down due to poor heat displacement. It's a tricky area to talk about. unfortunately, we can't have both silent and super duper air pushing fans without expecting a bit of noise from them (not without spending stupid amounts of £££)
Controlling case fans with PWM signal from motherboard CPU fan header and GPU fan header.
There are some limitations:
- Obviously motherboard and GPU must have PWM
- Obviously fans must be PWM
- Motherboard can only support 8-9 fans (PWM signal strength gets too weak)
- No idea how many fans GPU can support.
Setting up motherboard PWM control of PWM case fans:
- Use a PWM splitter with molex/sata connector. Gelid and Swiftech are my preferred.
- http://www.pccasegear.com/index.php?main_page=product_info&products_id=17923
- http://www.swiftech.com/8-waypwmsplitter.aspx
- Plug PWM splitter to motherboard CPU fan header and PSU
- Use CPU cooler fan as "master" fan. This is the fan that sends rpm signal to motherboard PWM header.
- Additional CPU cooler fans and case fans will ramp u and down with CPU fan.
- Can use a second PWM splitter on 3-way & 4-way PWM splitter.
- Setup fan speed curve with motherboard bios or software. Gigabyte has EasyTune 6 and Asus has SmartFan. I set minimum at 30% fan @ 30c and maximum at 100% @ 65c. Than watch temps and see if you want more or less rpm to keep temperature and noise where you want them. My sig rig idles 24-29c @ 700rpm; 100% all cores is 42-48c :950-1050rpm.
Setting up GPU PWM control of case fans:
- Obviously GPU fans need to be PWM. Because the GPU PWM header/plug is smaller than normal PWM we need a Mini 4-Pin GPU (Female) to Mini 4-Pin GPU (Male) / 4-Pin Fan (Male) Cable Splitter Adapter is needed-. The blue wire going to normal PWM socket needs to be cut off of mini PWM plug. (You can use this wire to monitor rpm on case fan by connecting it to a normal 3pin fan plug in the rpm position.) Plug a PWM splitter into the normal PWM socket and PSU for case fans.
- http://www.moddiy.com/products/Mini-4-Pin-GPU-(Female)-to-Mini-4-Pin-GPU-(Male)-{47}-4%2dPin-Fan-(Male)-Cable-Splitter.html
- Case fans hooked onto this splitter will ramp up and down with GPU fans.
- Use GPU software or Bios to setup fan speed curve
With no fans at all (other than the GPU) in the case?
TY-147A are fantastic, (no pun)! I use a lot of them. Thermalright has made some square ones one. TY-147A Sq. I've used a couple and they are same as TY-147A in a square housing. Absolutely great!
