***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Yip its the Moonshot, and its a great we tank, flavour off it is really good, better than my Cruis, i have a dual 317L SS coil build in it, about .25ohms.. TC limit set to 200 and im hitting it currently with only 55w on the Pico and only hitting 130C lol, ive had it on my DNA200 at 100w with 120w pre heat and still Not hit TC... its amazing for all the size of it. Its actually the Moonshot NANO and there will be bigger versions coming soon...
On the downside though...
1. Only holds 2ml so empties Real fast.
2. Drip tip is way to short and close to the top cap, so i have put in a delrin DT to avoid burnt lips.
Can it run a single coil set up? No idea what I am doing wrong but I can never get a dual coil set up to give me great flavour..
Might go back to basics with Kanthal. SS single coil in temp mode has been my bread and butter recently.
My iStick Pico just turned up. What a lovely little mod.
I bought the version that came with the Melo 3 tank (got tons of Triton coils I need to use up) as it actually seemed to be in stock at FT. Tank is OK as a beater I guess.
The Moonshot is designed for Dual coils only sadly.. thats why i have a Wotofo Serpent Mini on order ...
Oooo... looks intriguing. I come back to this forum for one day and I already have a list...
Wotofo Serpent Mini on a iStick Pico could be a fun set up.
Origennie looks intriguing but haven't delved into the depths of gennies. Might have to pick some brains before that...
Another alternative for you, the Goblin Mini V2, it does dual or single coil and looks cool on the Pico and is about the same size as the Moonshot :)
Not used my Supreme much but recently re wicked it a couple of times and it insists on dumping liquid out of the air holes :/ Think I may shift it on and grab myself a Moonshot I don't mind carrying around a unicorn bottle.
Anyone who owns the Moonshot does it leak since correct me If I'm wrong but you cannot adjust/close the juice flow off? So if it's in a pocket/left overnight etc does it leak.
Ive been running my moonshot for just over a week now, not leaked once on me, but i have seen some juice or condensation around the airflow now and then, rather like the Cruis does, but nothing major or bad...
I always close the airflow control ring before opening the top though...
If your Supreme is dumping liquid it's for one of three reasons:
Your wick is touching the walls of the chimney section
Your juice-control is too far open for the viscosity of your liquid (I have mine 1/2 open for 80/20)
Your cotton is not covering the holes on the deck
Sort those out and it won't leak. I have 3 of them.
Condensation doesn't bother me I just don't want it to empty itself all over my mod/pockets like the Supreme is currently doing although I know it's me more than the Supreme causing the problem I guess but back to the Griffin for the time being, Just feel the Moonshot will be perfect for my VTC Mini and heard the flavour is great on them.
Yeah, I know it is down to my wicking which in most other RTA's I don't have issues I tend to do a decent job but for some reason the Supreme always catches me out. Cotton definitely covers the holes on the desk so it must be a mix of cotton touching the chimney section/juice control being far too open... Will have another play with it this evening.
Well ive been carrying my moonshot on the Pico in my top pocket all day and ive been running around work, crawling under desks etc... no leaks.
Flavour wise, i have my favourite ADV in it, been vaping it over a year now so know how it normally tastes in my other tanks and can honestly say its tasting better and smoother in the moonshot, this is compared to my Aromamizers, Cruis, Griffin, Subtank and Serpent
It's a gennie is the sence that you can run mesh on it, but most people; me included run cotton on it. It's what the Wismec Theorem, GeekVape Avocado, Limitless RDTA and a few others all try to do... heard mixed reports on all the atties so I kept with the original design; which I really do enjoy enough to have two of them. :)
Is it just as simple as doing dual vertical coils and sticking cotton in till it touches the bottom of the tank?
Been vaping over a year now, I think - I can 'talk shop' with most of the guys in the local B&M, I have a bunch of mods and more than double that in tanks, yet I'm still all-at-sea about all these different ones you lot talk about that I've never even heard of!
Really makes me wonder if I'm missing out on something, or if they're pretty much all the same even at that level.
Yes buddy... AFC is big enough to lung hit.. I normally vape it at 30w on the second biggest afc hole which gives me the restricted lung hit I like.
For a true gennie, imho the in'ax is king.
To be honest they pretty much are all the same when you get them set up right. Slight variations in clouds, flavour, required power, airflow, style of vape, etc, but there are so many atties you really can't go wrong with now.
I run a Supreme, Avocado, Theorem, Kayfun Mini V3 and Aeronaut, and I love them all. The supreme takes a lot of watts and holds a lot of juice, gives a boatload of flavour with a boatload of airflow, it's my go to driving tank. My avocado is set up with a micro fused clapton at ~15-20W for a good flavour, relaxed lung inhale. My theorem has a bigger fused clapton, run at ~50W, produces a very thick, creamy vape, brilliant for creamy liquids. Kayfun is for relaxed, evening MTLing or for taking places where a great big chonging lung inhale is inappropriate, but still with excellent flavour.
Aeronaut has been the latest one to come back into my rotation, I've got a 0.18 ohm fused clapton in it, on a stingray X clone. When I first got it I just couldn't get much flavour out of it, now I seem to get tons, but it's very "clean" if that makes sense. I can pick out a lot of notes I can't get on other atties, so it's a perfect tasting setup for my mixing.
It's because with most other tanks, the juice goes down into the channels and then UP through your wicks, so you can get away with a little lack-of-sealing. With the supreme, because the deck is right at the base of the tank, there's a whole tankful on top of it pushing the juice through.
I've found the best way to ensure there's no leaks is not just to cover the holes, but do your best to make sure the edge of the wick comes up to the rim of the deck, all the way round. Also, check underneath the positive post - there's a gap there, which it can leak out of if there's no cotton filling it.
There's a lot out there, lots of it is the flavour of the month or just hype..
Mod wise it's all to do with style and delivering the power correctly but at the end of the day it's just a battery holder and a cheap dna 40 mod will do pretty much the same as an expensive dna 40, it's then a matter of eye candy.
With atties is where all the hard work is done, I much prefer to spend my cash on an atty rather extra on a mod.
there's many different styles and it's about finding the ones that best suit the way you like to vape. I've found that a 30 pound atty of a certain style will vape pretty much the same as another 30 pound atty of the same style. I can pretty much look at an atty now and know if I'm going to like it or not.
There are some outstanding atties but the best atty is the one that you spend the most time with, with enough time and effort you can pretty much get to vape good. after a while; I can get most atties to vape the way I like it. :)
Status
