Spec me i7 6700k setup
Don
21 Oct 2002
Parts Unknown
Looking to replace my 2500K setup as my motherboard is getting flakey.
6600K doesn't seem like a big jump from the 2500K. So I've decided on the 6700K :D
I'm a bit out of the loop with latest ram and motherboards.
Typically I go for Gigabyte or Asus, but I'm open to anything.
I'd like to possibly get an m.2 SSD too.
16GB ram.
My psu should be fine, just looking at cpu/ram/mobo
Sold!
Thanks.
Finally, dual bios via a switch, I asked GB to do this when I had my first Athlon 800.
Ooh, I'll need a new cooler too.
Corsair H75 looks decent. I can mount the radiator against the hard drive rack.
(Case is a Coolermaster ATC 110)
I know the bigger air cooling CPU coolers won't fit in my case as my case is ~150mm from the motherboard to the other side panel.
I'll be ordering soon :)
-edit, I can just squeeze in the H100i v2, I may need to Dremel out a bit of the CD drive bay, but that's not a problem :D
I'm pretty attached to my 110. It fits perfectly on the stand in my desk, a new case means a new desk too.
Thanks for your help gents. :)
Basically it has 2x BIOS chips, so if you screw one up, you can revert to the other and restore a 'working' copy to the original one.
Instead of having a non-booting motherboard.
