- 19 Feb 2007
- Northampton
Looking for a GPU with display port, As cheap as possible as it's just a place holder card until the 1080 comes out.
How cheap and what do you want it to run? Its only a fortnight till the FD 1080's are released, maybe just hang on?
Graphics card with display port output tend to start at around £89.99 on here, whereas card with DVI output start from £19.99. Wouldn't a cheap DVI card work, with a DVI->DP adapter? You'll have to sacrifice some Hz/Pixels, seeing as it's only a temporary solution I suppose it depends on whether you're willing to compromise on that.
^^not a bad card at all either. Used to get me nigh on 60fps at ultra 1080p on battlefront.
