The unpacking process takes its time...
Can you close the VPN whilst it's unpacking? Rest of internet is slow otherwise?
  Think thats it on ultra nightmare with cinematic effect enabled.  Doesn't seem to be a built in benchmark
I'll be interested to see how people do running this on a single 970
They can do what they like once it is bound in a legal document.
It's very taxing maxed out at 3440x1440 i'm getting around 60fps on sli 980ti. It does support 21:9.
That said the movement and gun play is super smooth and it looks pretty decent.
No nivia geforce profile yet for those who want it.
Some 4k piccies
Gunplay seems very solid as is the movement, the glory kills are very fluid as well.Think thats it on ultra nightmare with cinematic effect enabled. Doesn't seem to be a built in benchmark
After looking through the options again ultra nightmare doesn't seem to be an actual graphics setting. Nightmare is found under show performance metrics but the actual video options scale upto ultra. Unless nightmare is the addition of the cinematic, gritty effects?
Its a bit farcical that they think they can do that, if this was enforced they would essentially be banning a pretty large chunk of their user base. If the games paid for I don't really see the issue, not as if you're pirating a product.
The 1920x1080pixel display delivered 50-55fps results running on OpenGL, running on a id Software dev machine with a GeForce GTX 1080 handling graphics. The demo, though, ranged between 120 and 200fps once Vulkan was enabled, and remained above 120fps — a massive performance boost even within the likely carefully selected demo environment. Nvidia’s graphics cards for the last few years — all Kepler, Maxwell and Pascal parts — support Vulkan.
Vulkan support should be added “not long” after the game’s imminent launch, according to the devs, although OpenGL will be the only option straight out of the box.
The issue is tax. When you buy from NZ for example, the UK does not get the tax.
Roll on Vulkan patch!
There is a difference between buying and unlocking early from NZ.
Buying is understandable. Unlocking a game early they don't care even when they say otherwise to cover their own back.
GFX look good, framerates not as high as I thought it might be. And I've never liked the film grain effect in games, hopefully it can be turned off?
What are you using to display the GPU details on the right side of the screen?
