thank you!Lovely![]()
They look nice but I would not recommend if you care about performance. They are pretty weak and in a large case with large rads the hot air accumulate inside a lot. And thank you!looks awesome!
cant help but cry out for Parvum to make the white F1.0 in 140mm to fill a large case out like that.
How you finding them on your rads?
thank you!really sweet build and build log full props to you sir.![]()
I don't want to call it beautiful, simply being that would be a massive understatement. Them pipes really finish it off in a very unique way. Never seen them fittings before.
Top build - really tasteful components & scheme. I was considering the Phase II pump/res looks like a great combo. Wonder if a Bitspower D5 pump cover would fit at the bottom??
Well done on a great build!
