- 24 May 2011
It is about an inch of black border all the way round plus a small bezel, will try and get a pic.up this evening.
I wonder if anyone has could help with this problem. A mate of mine just picked up a acer xr341ck and a fury x. He is having a problem with the monitor displaying black borders around the image. CCC is not showing overscan options.
He has tried the following. All drivers all the way back to the point of incompatibility. Single monitor, low framerate, high framerate, 1920x1080, lower and higher. CCC wrangling through every possible alteration and variation possible. Complete resets of all files, reinstalls of drivers and resets of everything installed related to the monitor short of a Windows reinstall.
Any ideas for a solution?
Its part of the design, its not a completely borderless display
You have, as eazyrider says, about a 1cm border around the whole display. It is normal.
To be fair I hadn't seen the monitor but nonetheless I did feel a plonker for not asking if it was just the bezel! Ah well no harm done!
Arguably 10bit will not make for better colours than 8bit unless the content you choose to view is outputting at 10bit. Some.might argue differently but that is my understanding. For games and such an 8bit panel would be fine....that being said if 10bit alternatives such as this are no more...then win win!
Don't go Z35, just not the Z35. It's 1080p and VA (and 200hz not 144 btw), both of which are total no go on 21:9 35''
If you have that money to spend, you can go to town with the X34 or the ROG and never look back.
