Motion Sickness / Nausea - Thread
Caporegime
8 Sep 2006
On Ocuk
On the topic of car/game/sea motion sickness, how many of you actually suffer from it? What really makes you go bleeeeh? ;)
No hospital related discussion please.
As for me, yes I've had my eyes tested, but I've always wanted to try one of these and wondered if they actually worked
Don't personally as a general thing but the odd game (usually with nasty mouse input acceleration or lag, etc.) can make me feel nauseous.
My sister used to use those bands for car journeys and worked for her - she'd throw up once every 20-30 minutes without - with would make several hours (you can't really fake that heh).
Man up.
Although I do get a bit queasy when in the passenger seat. I think it's to do with not being in control/not being able to predict the movement of the vehicle and counter as easily as when driving.
Ah cool :)
I tell ya what really got me going though, was that Occulus Rift, played on a computer that really couldn't push the frame rates to make it smooth enough. Brother showed me the rollercoaster experience, omg I felt sick for days!
You can't Man up motion sickness, you either have it or you don't. If you do, you puke :D
Puke and then act like nothing happened/you're fine - manning up :D.
I wonder if those wrist bands would help me when I'm working in the back of a taxi. They always struck me as a con but didn't really look into them that much.
Just got this for £4.99 :)
AA Travel Essentials Anti-Nausea Wristbands, Prevents Sickness from Road,Sea,Air
The only thing that has ever had a negative effect on me was playing Alien vs Predator as the Alien. You grip a wall and run down a spiral twisting tube at the start, that made me feel rough but that was it.
My daughter suffers from travel sickness. In the last 3 weeks we've had a 20 minute journey in a car that smells of 30 minute digested Haribo and an hour journey with just your normal vomit smell. Then had the pleasure of steaming it all out. now that smells lovely...
My wife mentioned the wristbands, but do they really work? I would have thought it was just a placebo?
See that's what I thought about them. Seems there's quite a lot of positive reviews but I'm struggling to find any evidence to back the concept at the moment.
Heck placebo or not if it works it works I guess.
Its basic acupressure whether placebo or not seems to work for some people.
I suffer from it really bad, I cant go on boats, fair ground rides that spin, cant even play FPS or watch movies like Blair Witch Project, although I seemed to have gotten over being a passenger in cars, coaches etc.
The only time I ever remember feeling even remotely ill, was when I played the original DOOM on Steam. The speed of that game is just too much.
Only time I get it is on the tilting Virgin Pendolino trains on journeys over 1 hour, or if I look out the window in the back of a car for a good while. Ginger biscuits (or anything else ginger) helps, as do motion sickness tablets, but the latter put me right to sleep too...
The only time I felt a bit queasy was after 5 laps as a passenger around the Nurburgring in an M5 driven by a very fast lunatic!
Edit; after that the car limped off for it's hourly petrol feed, and new tyres!
Man up.
Nausia is controlled by the brain, not the guts.
Motion sickness is basically a "Safe mode" for the body. In much the same way as an engine ECU generates fault codes if some of the inputs do not match up (A common one is manifold pressure and airflow in the case of a faulty airflow meter) and puts the vehicle into "Safe Mode" to prevent further damage.
If the sensory inputs from the Eyes and ears do not match up. Your brain generates a "Fault Code" in much the same way.
Say, You are on a ship, your eyes are telling you that you are in a room, your ears are telling you that you are moving all over the place (Balance).
Or
You are playing a action video game, your ears are telling you that you are sitting in a room, your eyes are telling you that you are moving all over the place.
Because they do not correlate, Your "Body control Module" doesn't know which inputs to believe, the BCM "Software" then puts you into "Safety Mode" by making you feel ill so that you sit down to reduce the likelihood of harming yourself. It also makes you throw up in case you have eaten something poisonous.
The trick is to try to correlate your sensory inputs. In a moving vehicle you need to look out of a window at a distant fixed object or (In the case of a ship) go up on deck and stare at the horizon.
And, of course, as you point out. Being in control of the vehicle also helps.
The worst motion sickness I've had was as a passenger at the Nurburgring. Didn't chuck but got quite queasy! I'm scared as hell of vomiting anyway, so I get a panic attack if I start feeling sick.
I get horrifically motion sick on coaches (and buses somewhat). I don't really take the coach much really since getting a car, but I took a mini break to London/Brighton this past November and decided to take the coach to save the parking and petrol.
Going from London to Brighton was awful. I was in sweats and felt like chucking the entire trip. I've tried the ginger sweets in the past but they don't really do much. I was sat near the front and was sucking on a mint to try and help, but it didn't do anything either.
