How does this monitor fare? Can't tell what refresh rate it has either.
If a monitor has 10bit colour, does it just mean the quality of colours will be richer / more vibrant than an 8bit one?
https://www.overclockers.co.uk/iiya...s-widescreen-led-monitor-black-mo-133-iy.html
Edit: I see it has a 24 - 75hz refresh rate. How does that work?
That monitor is really 8-Bit+FRC . Like all 10bit consumer IPS panels.
Also avoid it, if you want a good one go for this, they can be found for £495-£500 :-
https://www.overclockers.co.uk/aoc-...escreen-super-wide-led-monitor-mo-026-ao.html
I have one and it overclocks to 75hz too. The iiyama is basically the same panel but the build quality is cheaper and more plasticy and the stand is poor too.
If you want to go ultra-wide and 3440x1440 at £500 mark and not bothered about 100hz screens and not wanting curved, this is the one to get and I rate it highly. Really pleased with the purchase.
. That pop is not a fault just as you realised the DP audio starting up and creates that pop sometimes, scared hell out of me the first time it happened then realised the second time it came from the speakers not the panel and muted the audio on the monitor and never happened again.
Darn pro's and cons. However in regards to the Ultrawide IPS's you are right, early models like the UM65 and the um95 have been notorious for glow and backlight bleed issues. However the 7 and 8 models (etx um57,um67, um68,uc88 and so on) are supposedly much better and my own experience confirms this. My old(and now sold) 29um57 was near perfect in the backlight and glow issue but ofcourse i understand that it could have been a lucky one.
