I'd imagine it will be a very, very aggressive fan profile. As in, it sounds like an aircraft is about to depart your sitting room aggressive!
Big Ti/Titan rumoured to have 4500cores!!!
Now THAT would be a good upgrade![]()
Sorry i should have added i didn't take in to account of the FE. I was just basing it of the normal 1080. and i purchased a 980ti the other month and payed £635 upgrading from my old 780. I'll add if the standard card is -£600 it's reasonably priced for sure.
Just my take though![]()
He's talking about the Hardware Canucks custom fan profile though, not the default one. They had to set a more aggressive one to prevent throttling. It's fine and dandy the default fan profile being quiet, but it comes at the expense of performance it seems.''But at roughly 80 degrees C and at that level the noise levels are okay really. In idle you can barely hear the cooling solution and under stress, well you can hear some airflow and that's it.''
http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_1080_review,30.html
30-40% in DX12 titles, which is insane.
No it tells us that the card is hitting a powerlimit.
Not for me. I have the cash need a card but its too expensive. I think kitguru said in conclusion that its was cheaper in comparison to a titan x.
Moment I reached the conclusion no- way. Trying to put a positive spin on two overpriced items from the same company was my take.
Far too rich in price for my taste and the value in comparison argument did not work for me, had rather the opposed affect.
The Guru3D review mentions that the card and the new overclocking tools require a new, specific driver to function, so I imagine all reviewers will be using that one.Are they running newer drivers on the 1080? I wonder if they're keeping a little dx12 love back from maxwell a la the 390x launch.
Then the market would have dictated that I was wrong and the price is acceptable and not overpriced like I, and others see it.
You won't be getting one then?![]()
I would rather go back to console gaming,than give nvidia my cash.
Can someone sum up everything since ~4am?
Every time reviews hit there's like 20 new pages to sift through.
