Yellow Submarine Build
9 Jan 2013
Hello,
I would like to share my build log with you guys
The parts I have chosen are as follows
Case "Thermaltake Core P5"
Processor "Intel Core I7 6700K"
Motherboard "Asus Maximus VIII Gene"
Memory "Corsair Vengeance LPX DDR4-2666 2x8GB"
PSU "SuperFlower Leadex 1000w Platinum"
SSD "Samsung 512GB 850 PRO"
Fans "4x Corsair SP120"
GPU temporary "Asus Strix GTX 960 replaced when 1080 arrives"
Water-cooling Parts
Pump /Res "Pacific PR22-D5 Silent Kit Pump+Reservoir, POM+PMMA, Reservoir 220mm"
CPU Block "EK-Supremacy EVO (Original CSQ)"
Radiator "480mm EK-CoolStream XE"
Fittings "EK 90'S / Alphacool compressions for HD tubing 1/2 /5/8"
Tubing "EK-HD Tube 12/16mm
Liquid "Mayhems Pastel Yellow 1L"
+ Phobya pwm 6 way fan splitter
now the parts are out of the way lets get to the good stuff
OP
9 Jan 2013
Fans Res / Pump and Riser Card
At this moment I was making the loop up in my head no planing involved all done on the fly, just the way I like it :p
Motherboard cpu block and temp gpu
4 Jun 2007
Watford, UK
Still, you got it done in an evening - that's pretty quick for a bent system. Normally much more swearing and re-bending involved!
Not sure how I missed the pastel yellow coolant in the 2nd pic of post 7! Name makes sense from there on.
OP
9 Jan 2013
Thanks snips86x
cenedd yup there was a bit of swearing as i didnt have the correct rubber insert when bending,
2mm smaller as the EK ones would simply just not fit was very tight, that was a big bummer as i had to be careful about flat spots
29 Dec 2014
The "North"
This system looks great, so clean and well thought out with no clutter. Wish I could have a system that is so stylish and open but the dust.... it everywhere :D
Seriously though, how do you control dust on this and great work :)
OP
9 Jan 2013
i will be adding the Gtx 1080 in the loop once arrived and purchased,
Temps are not to bad i got a 4.5ghz overclock stable 24 hour tested
30 mins of prime95 small ffts for a quick temp test
This is with the cpu de-lidded
Noise levels are virtually silent, its on the desk so dust is not an issue for the moment, (I will be bringing out my small leaf blower to rid of any dust in the future)
