Caporegime
- 8 Jul 2003
- In a house
Id give a pre-crimson set a try.
Yeah AF is all locked then, it's set at startup.
As for slots, yes, the 295x is in the first slot and 290 in second slot... and when I disable XF then the 295x still throttles down...
Uninstall the drivers and MSI AB. Use DDU to clean up the drivers afterwards.
Also use CCLeaner to remove anything on the registry might be left behind from MSI AB.
Then install only 16.5.2 do not install MSI AB. And play some games.
Let us know if that resolved your issue.
So whats the conflict between AB and crimson?
You know?
Just curious.![]()
MSI AB has provided me many issues with Crimson and 295X2. Since then I abolished it all together, and still do while using the Nano since January.
AMD overdrive is more than enough to do what we need tbh.
I dont use overdrive, i never mess with it at all (disabled)
I read its still buggy...so yeah.
What about trixxx is it reliable?
Well no strange crashes two days into new latest drivers!
Lets see if AMDMatt can answer to this...
Is there Crossfire support for Doom?
