^ I like that
Right, cabin ordered. Went for:
http://www.summergardenbuildings.co.uk/products/log-cabins/log-cabin-11105462.html
Spec:
- 5.0 x 2.6m
- 600mm front projection
- Door on left hand side & hinged left hand side (viewed from outside)
- 70mm walls
- 28mm floor
- 19mm roof
- Felt shingles
- Custom height (will be a shade under 2.5m)
Delivery 6-8 weeks (advised it'll likely be the full 8).
I now need to look at insulation. Can anyone advise?
I plan to insulate between the floor bearers under the boards and on the inside of the roof boards (roof is lower priority as this can be done almost at any time).
The floor bearers are 70mm pressure treated, so based on this, what should I be doing in terms of insulation? I'm thinking 50mm Celotex, but not 100%. Should I consider a vapour barrier/DPM, and if so, were should this go (I've seen some people use DPM on the tops of the bearers)? How should the Celotex be fitted/fixed in place?
The same goes for the roof really, thinking 50mm Celotex between joists, but also concious that I will probably need to consider a vapour barrier. Where should this go, and what should I use?
An idea of layer-by-layer configuration would be good, as it currently stands, the cabin will have:
Floor:
- 150-200mm concrete base
- 70mm pressure treated floor bearers (insulation between)
- 28mm floor boards
Roof:
- 120mm joists
- 19mm roof boards
- Felt shingles
Any suggestions for insulation would be spiffing. Ta!
