does new SSD come with SATA cable?
Motherboards often come with cables, including Sata.
Cheaper boards may come with less cables
Hard drives and ssd don't normally include a cable.
The main thing I forget is monitor cable.
I've bought drives with, some without, The intel ones I've bought all come with cables. The crucial ones didn't. Don't know bout kingston.
I've never bought a motherboard (Abit, Asus, Gigabyte) that hasn't come with some cables.
Except for B-grade items, all motherboards come with some SATA cables. The cheap ones may come with 1 or 2, more expensive boards can have more.
Some of the SSD retail packs do come with a cable (and often a drive bay adapter), but you pay over the odds for it.
Some monitors come with cables, others don't.
I've always found that the 'OEM' drives come without the fancy packaging and cables you get with the retail versions of the same drive.
Motherboards typically come with an assortment of cables, always best to check what's included before you purchase though.
