Caporegime
- 18 Oct 2002
same way aliens might knock on your door and say we going to beam you up and do some probing? at least they give a fair warning first right?
Ummmmmmmmmm..........
wont be enough.
Only one card to rule all other cards and its called Rx 480 now
E3 going to be interesting as partners are really hyped for this card.
Hyped!
The best thing about the AMD Live stream was this ...
Re MS rep
53:18 How many here are running windows 10 about half the room place there hands up ... how many people like windows 10 about 4 or 5 put there hands up EPIC FAIL..... after the poor response he steps back and he as to resort to saying "if you find it not making your expectations file in those feedbacks" what a mess M$
I love the fact also that he is using the old trick that if i hold my hand up you will too !
https://youtu.be/ZwlQvjwYFEM?t=3194
Very interested in the P10 and the price it will be ...
why nobody is talking about the elephant in the room, perf per watt, down to x1.7 instead of x2.5 in the roadmap slide
ashes bench shows that 1080 is about 70-80% faster, although it's hard to say thats dx12, need dx11 games to have more accurate read on performance, and i think performance will be lower than we expected, slightly higher than 970, the 480 might beat the 980 in dx12 games, but could be consistantly beaten by 980 in dx11 games by a fair 10% margin, although with that price i dont really care 199$ is perfect pricing for that perf at the moment.
now i just hope they have a higher card than what they showed with extra 20-25% perf for about 299$, unlikely but one can only hope.
They show 1.7, and then x2.8 with architectural improvement. That's more than the Up To 2.5 they talked about late last year when demo'ing Polaris running Battlefront.
LOL loving the Windows 10 comments - I've had feedback on critical bugs filed for 9 months or more that still haven't been addressed never mind quality of life/experience feedback.
No one knows, but they did say polaris will range from $100-300. And the RX480 4GB is $199, while the 8GB is $232, leaving $232-300 for a 480X part.
I somewhat assumed that $300 puts a top pricing limit on AIB/custom/overclocked versions, but we will see I guess.
Wait, I've skimmed through the Polaris bit just now from the stream. Ashes bench, 1080 98% utilization and 59 fps, 480 cf 51% utilization with 62 fps. In theory, 480 cf at 95% utilization would be what, 115 fps? Isn't that like, double the performance of 1080 for $200 less? Even if utilization:fps is not linear, 480 cf with proper drivers should hit 100 fps, and again I'm assuming, that cf scaling is a least 70% a single 480 beats 1080? What? Or have I messed up my maths somewhere? I probably did, only up for 10 minutes or so.
Yeah, no one's really sure what's going on there.
Since that also suggests a single 480 is the same speed as the 1080 (in ashes anyway) for $199.
Also it occurs to me, if they're now claiming a massive 2.8x perf/W increase (in max ideal conditions of course). Doesn't that mean they're saying they could do 390X performance at ~95W? If so, maybe the card people are saying around 970 performance is actually the larger Polaris 11. Since that would allow them to get 970 performance at ~80W. And largest Polaris 10 could be faster than people are assuming.
PCB looks very short indeed - the cooler overhang seems similar to what Nvidia have done in the past.
Can we start shouting 'nVidia is DOOOOOOMED!!!!!' yet or not?
Since P11 is going into laptops, I can imagine £800 laptops pulling off 1080p60 (maybe not ultra) easy if it will have 970 perf at 80W or less.
Back to 480. 1x 6pin means 150W tdp, add 2.5x perf/W and you get 375W Fiji ~ Fury/FX? Way to rain on nVidia's parade.
It just means the board can draw up to 150W. Since once you need over the 75W the PCI-E slot can provide, the smallest auxiliary power connector for 12V is a 6pin connector. The card will more than likely use far less during normal use.
Pretty good mainstream launch from AMD.
Also this seems like believable now.
The 480 is between the 970-980.
True of course. It does also mean though, it gives them a lot of room to offer a lot of performance even at low power (depending on how well this 2.5-2.8x scales).
Potentially they could make a 200W card (as in draws 200W) which would be faster than an overclocked 1080.
The 2.8x figure was "using AMD technologies", its similar to Nvidia's VR performance claims
The real figure is 1.7x
