As your hardware would already be registered with the MS activation servers for windows 10, you can just swap the hard drive for the SSD and do a clean install without activation throwing a hissy fit since it wasn't the motherboard being changed.
			I was on win7 but for no reason my pc has auto upgraded to win10 whats all that about
If you do the free upgrade to 10 and prefer the old version can you roll the install back or do fresh install with the old version? Sure this has been answered but didn't see it in the OP.
So with the cut off looming and me using my pc for pretty much nothing but gaming, I think I should reluctantly upgrade for dx12.
This was installed with an oem win7 key, so I know it has to be upgrade, rather than clean install. But is there a best way to do it? or just through windows update is fine?
Also, I know updates can't be turned off on 10, does that go for drivers as well? Don't really want my gpu drivers updating by themselves, as Nvidia and Amd have released some dodgy ones recently, so normally wait a while before upgrading.
Thanks.
If I can't download it, is there at least a way for it to stop trying? I see this is a widespread issue.
