So yesterday when I was filling up I foolishly put a small amount of diesel in my '06 Prius (the meter got to around £2.50 before I realised). I thought I would be okay if I just filled up the rest of the tank with petrol (which is what I did), but I've just went to start it and it's dead.
It did start at first, but I think it was running on the residual battery charge because the engine didn't kick in and the fuel gauge showed empty. I drove it around 10 miles home from where I filled up and then used it again later that evening.
What should my next moves be? Is draining the tank and refilling likely to work or will it have caused more severe damage? I did read somewhere online that diesel in the tank can cause the gauges to go haywire so maybe if I can get it running and top up with a bit more petrol it will eventually 'flush' out the diesel?
