To me the Brodit ones look like something you'd attach your Nokia phone to in the 1990s.![]()
I would argue the other way.
Air vent mounts seem so stuck on.
I have a brodit mount on my A pillar in my V70 with one of there active chargers attached to it.
Can get a pic of my car to update but its basically as below with the charger attached:
http://www.brodit.com/images/s425/804675-4.jpg
The cable from the active charger goes straight into the A pillar so you cant see any cables and its wired in under the dash.
This means my phone slots in horizontally (can be mounted either way) and I have NAV etc right in my eye line.
Also on a 3 hour trip or whatever I can stream music and run NAV and not worry that my phone will die.
I hate cables dragging everywhere and this is the best solution I have found so far.
