Ubuntu home server network not working after update
29 Dec 2014
The "North"
Hi everyone, yesterday I updated the home server via webmin and since then I haven't been able to get any network connection on my server. It can identify the network adapter and no settings appear to have changed but it refuses to receive/send any data.
Does anyone have any ideas on what may have caused this and how I should go about fixing it?
SSH into it and do an ifconfig from the command line.
It's because Webmin sets the network addresses and such but doesn't do it right. You're better manually editing /etc/network/interfaces and leaving webmin alone when it comes to IP configuration.
Hardware? Ubuntu release? Network adaptor kernel module version? Network adaptor?
Ubuntu is 16.04 LTS
Network card is an Intel I217-LM
No idea what the kernel module version is
It won't even connect to the router for me to SSH into it :(
EDIT: Fixed, someone unplugged the powerline connector causing them to reset/unlink :mad:
LOL at least it was something easy.
Do be aware though, I have the same setup (Webmin over Ubuntu server). I've stopped making network interface changes over webmin because it kept screwing up the config files and bringing no interfaces up.
A valid work around to that is using the cli on the box itself (not SSH like I said) to edit the interfaces config page.
Probably not too much of a consideration for you if the connection in is over powerline but have you looked at Ubuntu's built in ling aggregation / bonding? It's incredibly easy and satisfying :D
I have done on other servers, must admit I only use webmin for updates but any configuration I try to do over SSH as (like you say) it has a nasty habit of borking things :D
