I'm hoping someone can point me in the right direction for fixing my wife's bike as I'm pulling my hair out trying to sort it.
It's suffering from fuel starvation when at full throttle for more than 15-20 seconds. You get a splutter as it starts to die but lifting off for a few seconds and/or running at ~80% throttle fixes it.
It wouldn't be an issue but it's only a 125cc 4 stroke (Aprilia Mojito 125) and she goes down NSL roads so full throttle is needed sometimes!
I've done the obvious things such as changing the filters, spark plug & vacuum line to the fuel pump. I've also replaced the fuel pump itself as it looked a bit grotty and I wanted to eliminate it as the culprit.
All of the vent pipes are clear, the fuel cap isn't vented but I've ran it with the cap loosened and it still cuts out.
Other than stripping and rebuilding the carb, is there anything else it could be?
