I get a graphics score of 18360 with a msi 390 at 1080 core clock.
That would put the rx480 at under £200, £70 cheaper with more or less the same performance.
Not bad.
That score is higher than the Fury score posted earlier and higher than my overclocked 290X. Very strange.
Can you post a link to the 3dmark result?
The driver version is different from mine. I'm using the latest Crimson 16.5.3. Which driver are you using?
I am using 16.5.2.1.
It was 20683. CPU holds back the overall score a fair bit in this particular bench then.![]()
blimey...
shows how quick stuff is getting. this my system with my cards pretty well clocked! old girl does well but slowly showing her age
http://www.3dmark.com/3dm11/11299743
would be very tempted by a pair of 480s if the price really is true for UK
Wow amazing score for 2x 7950.
Looked through many forums, many were very disappointed with RX 480 performance. It seemed RX 480 will be aiming at R9 380 owners to upgrade for a nice performance increase around GTX 970/980 and R9 390/390X level.
Accorded to Eurogamer that GTX 1060 will be RX 480 competitor.
http://www.eurogamer.net/articles/d...-costs-199-gtx-970-r9-390-beating-performance
It should work. You can try it now in the Steam VR performance test with -multigpu switch added to launch options.
The system is called Affinity Multi-GPU (one gpu per eye) and is part of Liquid VR.
	Funny you should say that as I have witnessed the exact opposite.
There is an overall positive response to the 480.
Reddit AMD was trending massively yesterday. That's a global audience wanting to know more about a great price/performance card that's affordable.
Word has gotten out and I reckon AMD will do very well this this GPU.
This is my stock Titan X and 3930K at 4.4Ghz
http://www.3dmark.com/3dm11/11299777
Not bad at all for the 480![]()
No, because the 980Ti has always only been about 30% faster than a 980.![]()
Don't take everything so seriously![]()
