Win 10 upgrade
16 Jun 2014
Ok so I accidentally let my main pc upgrade to win10 and well everything is fine.
However, my old install had bloated and my c drive a 120 gb ssd was about 90-100 gb full and still is.
I already had my libraries on another drive (WD black).
Should I do another clean win 10 install or carry on, I don't see any issues right now, but I do fear there could be some later?
I know this means reinstalling all my files and drivers but maybe it would be worthwhile doing this now rather than later? Though I do like all my passwords etc not being forgotten!
You could use SpaceSniffer to identify any disk hogs. Also the built-in Disk Cleanup tool is great for safely clearing out old updates, installations and temp files.
I have one last question, one mroe pc to upgrade to win10.
It is currently win7 on a 64 gb ssd, it is too crampt and SpaceSniffer says there is almost 30 gb in winsxs. But I can't clean any of that it seems. There isn't enough space to do a win10 upgrade, but I have bought a new 120 gb ssd to replace the small one, so what to do? REplace the drive do a win7 install and then the win 10 upgrade or a straight win 10 install. The win 7 key is supposed to work, but my win 7 wasn't a retail version but an upgrade version! Any ideas? Also the board is an old gigabyte e45-udp r1.0 and there are no win 8 or win 10 drivers for it on the gigabyte site. Any advice on how to find the drivers for it? I'd rather download them a head of installing the OS and install them straight after...
I think you have to do the upgrade first time round to get the pc registered with Microsoft. Any subsequent installations can be done cleanly. I just upgraded to Windows 10 from Windows 7 on a 60GB SSD. It said there is insufficient space but it gave the option to use a usb drive to compensate.
Just clone your 64GB ssd to the new one then do the upgrade.
I've always had this problem if I clone it, wont it clone the partition and so be too small anyway? At least this is what I found with VMware a few years ago?
Which cloning software do you suggest??
Thanks for the advice, though I'm still a bit scared of this. I have found articles that say you don't need to do the upgrade first anymore but I'd not like to find out the hard way!
I've read that too. A lot of people here use Macrium Reflect. It's free and easy to use. Then you can use disk management to extend the volume to 120GB
Ok, so I'm falling in love with Macrium but have hit a problem. I'm imaging the os partition from a laptop it is 200GB, I'm putting it on a 240 gb ssd. The original he'd had a 25 gb recovery part the 200 gb os part and a 250gb data part. When I put the os part on the new disk if I leave an empty 25 gb it works but if I put the Os at the front of the disk so I can extend the part to the full 240gb it won't boot, says a device is missing. Any advice?
