- 13 Jan 2004
- South East
Oh sorry, not yet. There's some on YouTube though if you search for it. I don't think I've even driven the car at night since I got it a week ago!
I have the blackvue dr3500 fhd
Thats it in my 7 series, and powered from the overhead lighting area, so no dangling cables.
Manual install is easy, and they can be hidden away nicely. Mine did go faulty once (after being out of the car for a few weeks) but was replaced quickly without a quibble from the UK supplier.
I did the same in my old XF too:
Much neater and more discreet than the big sucker mount units, and with no screen its less to go wrong and means you get better optics and other important stuff!
Look pretty good and discreet. That's what I'm trying to go for. Was it a breeze to install yourself or shall I get someone who can install it properly.
Thanks for the reply SS, yeah being a new discovery though I don't want to be messing around with.. With that said.. I also don't want them messing about if they don't really know what they are doing.
I doubt they know what they are doing with regards to the car if its just a normal Halfords.
Unless its changed since when I used to fit for them (circa 10 years ago) you had some basic electrics course so you could hardwire a stereo in etc but that was about it.
Finding out how trim came off was trial and error but now would be Google I guess.
You will take more care than they will I would guess, although I was very paranoid about messing up someones car they wont all be.
