ultrawide suggestions please
30 Mar 2014
uk
hello everyone im looking to upgrade my monitor from benq gl2450 to an ultrawide monitor but need some suggestions of what one to go with size isnt an issue but looking to pay around the 200 mark maybe slightly more and ips if possible
pc specs:
core i3 4170
8gb hyper x ram 1600 mhz
sapphire r9 380 nitro 4gb graphics card
i mainly play csgo and other fps games and will be used for movies etc
thanks for looking and suggestions :D
Your best bet would be this one I guess especially as it has free sync.
https://www.overclockers.co.uk/lg-2...e-widescreen-led-monitor-black-mo-143-lg.html
Have a look around, I found OcUK very expensive for 29 inch screens. 29 is basically same height as standard 24 inch.
I recently got this one for little over 300 elsewhere
https://www.overclockers.co.uk/lg-2...e-widescreen-led-monitor-black-mo-142-lg.html
what about 1440p with my gpu? not sure whether to go with 21:9 or 1440p, or even if anyone else can chime in with personal experiences with 1440p
1440p UW is excellent, but you will struggle to max out certain games with your GPU, although CSGO would be fine. If you are planning a GPU upgrade though, you should consider the Acer XR34.
