creating bootable USB for win 10 64bit clean install
14 Jul 2005
Birmingham
Hi all,
I will be installing 64bit win10 on my new pc (building myself - don't have it yet).
I have access to a win7 pc at work which I was going to use to create the bootable USB. This system will just be used to create the bootable usb with win10 on it, and other than that is nothing to do with my new pc or new version of win10.
However I have come across a lot of information online that seems to suggest it is not possible to create a 64bit bootable usb from a 32bit system, using the microsoft media creation tool. My win7 pc at work is 32bit.
Can someone clarify this for me please - the information online is so sketchy and its totally unclear whether or not this can be done.
Thanks
Hi all,
Thanks
Try downloading the ISO from TechBench (https://www.microsoft.com/en-us/software-download/techbench) and then creating a stick (using the Win7 USB/DVD Tool or WinSetupFromUSB).
Thanks
The MS media creation tool will allow you create a 32-bit setup USB drive, 64-bit or both combined (you'll need an 8GB flash drive for the latter) - just run the tool, select "Create installation media for another PC" at the appropriate point, and uncheck "Use the recommended options for this PC" when it asks you to "Select language, architecture and edition."
Another useful tool is Rufus. It seems to work better for me than the MS utility.
While I did try the Micrsoft Toolkit, I sometimes found it doesn't always work for some systems, but Rufus did, so +1 to that. You can use the toolkit to download the Win 10 ISO, with a choice of 32, 64-bit, or both.
Run CMD as Administrator
Run DISKPART from the command prompt
To list available current disks, type LIST DISK
Identify your disk number (in this example I will use Disk 2)
Type in the following:
SELECT DISK 2
CLEAN
CREATE PARTITION PRIMARY
ACTIVE
FORMAT FS=FAT32 QUICK
EXIT
EXIT
Now, using a tool like 7-Zip, extract your ISO to the USB disk and it should work.
I think its worked.
I used windows media creator to download the 64bit windows 10 iso. This failed first time but worked the second.
Then i used rufus to burn that iso to my usb stick as a bootable drive. Although i selected fat32 i noticed rufus overwrote this setting to ntfs when it started the burn from the iso.
However the usb stick will open fine on my pc, so all that is left is to test whether it boots.
I didnt expect to be able to read the usb stick on my 32bit system. Is therea way to varify that i do have the 64bit version?
Don't worry about whether the files are readable or not, as files saved on a 32-bit or 64-bit system are no different.
The difference comes in the actual files included in some of the folders which control the resulting operating system when installed.
Follow this if you want to be sure.
Thanks. Didnt work at first but i think that link gives the wrong file, as it worked on the boot.wim file instead of the install.esd file which came back with an error. The boot.wim file is tagged as x64.
Looks like you used MBR mode but really, you want GPT for UEFI on a new system.
Right so just gonna do this again. When i select the iso file ive noticed it puts the settings back to default. So i need to select the iso file first and then change the settings.
I choose?
Gpt partition scheme for uefi
Fat32 (default)
8192 bytes (default)
Should i choose 4096 bytes cluster size even though 8192 is the default?
