Just a warning, in order to qualify for the cashback, the invoice you provide back to Dell has to include the VAT number of the supplier.
Just checked with said supplier and they say they haven't had any issues with this with any they've sold, nor can I find details of it on the Dell site. Hopefully it won't be an issue.
Please check your account with the reseller and look for the invoice which contains the VAT number.
Should you have any more queries please do not hesitate to contact us again.
Looking at this my N54L is showing its age. Currently I'd need it mainly as a desktop, changing to a NAS in the future. So I'd run Win10 on an SSD.. 2 x WD 3tb Red's, and 2 x random 1tb disk as backup...
As I understand it, I'll need the Dell 400-ACRR Sata power extension cable, and a random PCIE Sata Card to support the amount of disks. Don't care about hardware raid so that should do.
Ram wise, will the ram from my N54L fit?? For the moment, cash wise it would be easier if I could just reuse that, or do I need different stuff?.. Also could someone just outright confirm that non-ecc ram works fine?
Other then that a quick DisplayPort to hdmi adapter and I should be good to go.
All sound ok? Anything I haven't considered?
Are you going Xeon or Celeron?
The Xeon T20 does not need ECC RAM, I even had a mixture of ECC and non-ECC running in mine for a while, now it's fully non-ECC.
.Migrated the disk drives from my ageing N40L to my Dell T20. Loving the speed increase so far.
SSD as boot drive, 4x WD RED 3TB's
Purchased a Startech 6GBps PCI-E Controller card (PN: PEXSAT32) mentioned earlier in this thread; can confirm it works well, have the SSD.
Only thing that has let it down so far is the onboard RAID controller, was only getting about 30mb/s write speeds.. Resorted to a software raid5 under Win Server 2012 DC.
Exactly same setup as I'll be moving from and to this weekend. Glad to know its working well.
Are you using Storage Spaces for your software raid?
Any of you guys running VM's via Hyper-V ?
What setup have you allocated to the VM? Cores and Memory?
Set up vm's before but never took any notice of how much resources I was assigning to it (usually left it to defaults).
Thanks.Looking for a small server solution, Plex, Media storage and some virtualisation. Anyone managed to tick these boxes with the T20 as yet?
I also have the Xeon version. I put ESXi on it. I have multiple VM's for work, plex etc. Very happy with my purchase.
