The Pascal GTX 1080 Owners Thread
9 Dec 2006
@ManCave
For the FE owners, how does the fan perform out of the box? Is the throttling a problem when you leave the fan at stock settings? What software are you using to change fan speeds.
that's the exact testing im doing right now
i tested with my fan profile setting first so at
80c its at 65% (10% more other stock)
Mine
max temp 78C
average 77C
boost clock
1840mhz max
average is 1809Mhz
Min 1790Mhz
Default
already 3 Minutes in to the Witcher 3
Average temp 82C
Max Temp 83C
Default fan:
Min Clock 1603Mhz @ 82C
Average (only over few minutes remember) 1780Mhz
Max Clock 1809Mhz
So after very quick testing you loose a good 100mhz using stock profile
if you don't wear headphones it sounds little loud a definate whoosh noise but not an annoying whoosh
29 Dec 2003
UK
I didn't use it on default fan I like keeping my cards as cool as possible from the get go to, i used a custom 1:1 fan profile using MSI afterburner 4.3.0 beta 4, maxes around 70deg. The FE fan is very quiet imo.
Man of Honour
OP
21 May 2012
Dalek flagship
Founders edition getting 1820MHz constant boost :D
Welcome and on TROH.:)
The Roll of Honour.
Date 18/06/2016, Make Zotac Founders Edition, smogsy, Link
Date 17/06/2016, Make MSI Gaming X, Rasphelt, Link
Date 16/06/2016, Make EVGA SC ACX 3.0, Gripen90, Link
Date 16/06/2016, Make Asus Strix Gaming, grav, Link
Date 15/06/2016, Make Gigabyte Founders Edition, a66as, Link
Date 15/06/2016, Make MSI Founders Edition, Born_2_Kill_83, Link
Date 15/06/2016, Make Zotac Founders Edition, Hixxy0, Link
Date 15/06/2016, Make EVGA Founders Edition, jabski, Link
Date 14/06/2016, Make MSI Gaming X, Popov, Link
Date 14/06/2016, Make EVGA Founders Edition, Devious, Link
Date 14/06/2016, Make EVGA Founders Edition, Stelly, Link
Date 13/06/2016, Make Inno3D Founders Edition, CEUOTC, Link
Date 13/06/2016, Make MSI Gaming X, JABenedicic, Link
Date 13/06/2016, Make MSI Gaming X, Cochran, Link
Date 13/06/2016, Make MSI Gaming X, JLyte, Link
Date 11/06/2016, Make Zotac Founders Edition, avatar12m, Link
Date 11/06/2016, Make EVGA Founders Edition, crinkleshoes, Link
Date 10/06/2016, Make Gigabyte G1 Gaming, BriT, Link
Date 09/06/2016, Make EVGA Founders Edition, spiralz, Link
Date 09/06/2016, Make Gigabyte Founders Edition, WesleyBurns, Link
Date 08/06/2016, Make Gigabyte G1 Gaming, Gregster, Link
Date 08/06/2016, Make Zotac Founders Edition, Biffa, Link
Date 07/06/2016, Make Gigabyte G1 Gaming, Sasahara, Link
Date 06/06/2016, Make EVGA Founders Edition, Boomstick777, Link
Date 06/06/2016, Make EVGA Founders Edition, tyler_jrb, Link
Date 05/06/2016, Make EVGA Founders Edition, danw872, Link
Date 04/06/2016, Make MSI Founders Edition, easyrider, Link
Date 04/06/2016, Make Inno3D HerculeZ X2, LewisRaz, Link
Date 03/06/2016, Make MSI Founders Edition, DAIR, Link
Date 03/06/2016, Make Palit Founders Edition, Spikey, Link
Date 02/06/2016, Make EVGA Founders Edition, Radox-0, Link
Date 31/05/2016, Make EVGA Founders Edition, toon_mad, Link
Date 31/05/2016, Make Zotac Founders Edition, ToastedChip, Link
Date 29/05/2016, Make Gigabyte Founders Edition, kitkat9933, Link
Date 28/05/2016, Make EVGA Founders Edition, X-Mikuru_Beam-X, Link
Date 28/05/2016, Make Gigabyte Founders Edition, dvs8, Link
Date 28/05/2016, Make EVGA Founders Edition, passey89, Link
Date 28/05/2016, Make MSI Founders Edition, Biomorphs, Link
Date 28/05/2016, Make EVGA Founders Edition, RichardH754, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080.​
12 Jul 2015
It makes me happy to see people are getting their aftermarket cooler version! Now where's mine :o
I also like how Asus, MSI and who else make blower style cards other then reference design coolers. It's good for those who want that type of cooling but have no use for the reference cooler scheme, for example.
Caporegime
18 Oct 2002
Tbf Fear, the reference nVidia cooler is really rather good this time around! They've obviously put some thought into it this time round, what with charging more for it and all!! :D
Good bloody job tbh :p
9 Mar 2015
Earth
It does not throttle below base speeds, but boost drops off abit with stock fan profile, but with stock fan profile its still very very quiet.
A good balance I have found is using MSI afterburner (EVGA Precision OCX seems abit flaky to me) in which you can set up a fan profile manually. For me it tops out at 60% which is good enough to maintain 2000 mhz boost in SLI config (so including heat from bottom card going into top). 60% fan may sound loud but the FE cards is actually fairly quiet, at least compared to TX reference cooler, so its not notifiable really
15 Jun 2009
South London
Happy you enjoy your purchase but it looks like quite a few FE purchases have been made through sheer impatience (understandable if you have time booked off for example) to wait for the aftermarket versions which are much more capable of holding holding their higher boost clocks on auto fan settings.
20 Sep 2011
picked a FE from a local PC store next to me after OCUK didn't deliver on the 17th
anyway mine boosts to 1898 on its own, is this good?
20 Sep 2011
Have to say not seen many review's where the aftermarket out clocks the FE either. Certainly not worth the waiting pain I enjoy reading in the other thread, people are pulling their hair out while I'm enjoying mine.
x2
how do u think of it on ur x34? personally I think its a perfect match :D
20 Sep 2011
9 Mar 2015
Earth
It says for out the box boost on the gigabyte is 1936mhz and 10400 MHz on that same article. I expect 2.3 ghz is a cherry picked chip in a cherry picked scenario like nvidia did at thier showcase. Hope to be proven wrong but given the OC we have seen on all 1080s to date I doubt it.
