If you want to try and convince everyone its only going to offer GTX970 performance go right ahead. I doubt you will have many agreeing with you (yet again).
When was a GTX970 a $500 card, is RX480 at $199 not supposed to offer performance of recent/current $500 cards.
Not having DVI is a bit of a dealbreaker as I wont be able to use 120hz on my on monitor without spending a large amount on an active adapter.
Hoping AIBs have a version with DVI
Dude, you don't need a active adaptor, a passive would work.
DP carries 8.5 gbps and DVI-D has to be duel link carry's 10 both do 120hz at 1080p.
Yeah those slides from AMD with the VR test and info in the disclaimer slide are just plain pathetic if true.
It also says the RX 480 got 121 FPS in Overwatch, and that would put it behind both the R9 290 and GTX 970
Source: http://www.techspot.com/review/1180-overwatch-benchmarks/page2.html
But this can't be right, because a ~£230 card which delivers around 970 performance for barely less power would be madness on 14nm as a new launch.
Yeah I read Mauller's post....
Its not good is it?
@ Mauller
This... http://store.steampowered.com/app/323910
This thing is really starting to look like a complete let down. a step backwards in performance.
I am not just referring to the article headlines but specifics made during the presentation. Although any reason to assume why a budget component of the 1060 will beat the RX480?
Yeah, it wants a 4.7GB download when i go to use it.
1070 on right, 1080 on left.
Strange, download it, see what happens.
Ha, the 1070 that costs 2X doesn't even have the copper that the X480 has.
