Hi Baxter.
We don't void the warranty for fitting aftermarket coolers, unless they are damaged in the process.
So under normal circumstances this would qualify as user damage and the warranty would be void. If it wasn't an outsourced car (not built by Gigabyte) I'm sure our RMA center could attempt a repair but my understanding is that because is it an outsource card the NVIDIA policy is for the card to go back to them.
Send me a private message and I'll start a conversation with our RMA center to look for alternatives to solve your problem.
So, you don't void warranties void for fitting aftermarket coolers, but if the card dies after fitting an aftermarket cooler you deem it died from damage from fitting the cooler automatically thereby you deem the warranty void?
Is that not, in effect, saying you don't support the installation of aftermarket coolers?
Im sure you stuck this on ebay and a fb group.
That is not what he says at all.
Physical damage by being clumsy and fitting a aftermarket cooler VS genuine faulty part/fault.
Except the guy specifically said it worked for quite a while after the install and to him it looks like a poorly soldered capacitor has come loose. If Gigabyte automatically decide any and all faults can be passed off as blame for damage while installing.... then that is what I took from it.
He appeared to decide in one instant that this wasn't original damage but done during install. But if they decide that from one picture then it sounds to me like if a card breaks that will be their default stance.
Resistor blows on an unmodified card, well the resistor was bad, resistor blows on a card which had the cooler removed... oh well the customer must have hit it during installation of new cooler so it's customer damage, warranty void.
It's his response which worried me, the automatic assumption it was damage on the OPs part. He literally said under normal circumstances this would qualify as user damage... thus voiding the warranty. He has no basis to make that claim and looked to me like they will automatically place blame on user damage if anything breaks after a cooler has been changed.
Would need some proof that he has used for ages, could have just as easily fitted and damaged it and then noticed the cap and made this thread all in a day.
His bases for making the claim is that the OP has fitted the AIO and now there is physical damage to the card.
And the resistor hasn't blown as I see no burn marks or discoloration, its literally come away at one side.
im just a little worried why it instantly shot up to over 100degrees
So the pcb company just happened to have a coupole of gddrx5 modules sitting around?![]()
the overheat,
i had the cooler on for a week, decided to run valley, the temps shot up 1/2 way through, cooler is still ok, and the card shut down, up on removing the cooler the cap was hanging off!
iv had a phone call from the company, they have fitted a new cap, and two burnt out vram chips,
tested all work fine
total cost £91 inc VAT!
i must have jammed a screwdriver through the VRAM too, whist fitting the cooler! (wonder if RMA would say that too lol)
Also the PCB firm just happened to have the correct speed/timing ICs in stock...
Too much don't add up![]()
