- 10 Aug 2006
A cheaper and more efficient upgrade choice for those who have older/lower end cards.
Ah ok, thanks. I was hoping they would be challenging the gtx 1070.
Ah ok, thanks. I was hoping they would be challenging the gtx 1070.![]()
If true then price to performance:
Stock 480 (Ref Blower fan) - £230(Maybe) - 2096 = 12.6 points per £
Stock 1070 (KFA Blower fan) - £365 - 4290 = 11.7 points per £
Would 0.9 points be a big enough win in price to performance to warrant crossfire over 1 more powerful card, maybe not but both good price to performances for single card purchases depending on how much power you want.
EDIT: change to correct score and recal.
So my AMD 7950 2112 Graphics score beats a GTX 970 2058 Graphics score in Firestrike Ultra?
http://www.3dmark.com/3dm/5257360?
Clock speeds in the above link were actually 1200/1625
I guess it depends on what games you want to play.
There is not a single 1070 below 550 EUR where I live. Most custom ones are over 600 EUR. Not sure where you getting £365 from.
Well, rumors are calling it a great overclocker, but even then it probably won't challenge the 1070 directly. The 1070 is a much pricier card. It may be a viable alternative if you only want 1080p or 1440p at 60fps and the 1070 may seem to be overkill. If that doesn't work out, then it will at least grab the lower end market share.
How do you work out performance? It's no problem when comparing Nvidia cards to other Nvidia cards, or AMD cards to AMD cards. But, benchmarks and games can vary quite a bit depending on which brand card you use.
Is there a benchmark that doesn't favour any brand of card? And, we hear time and time again that none of the benchmarks are any sort of indication of game performance.
And then what resolution or graphic settings do we use? There is always games etc that one brand card is faster at lower resolutions than the other. And some cards have better performance at some at higher resolutions.
Sorry, those are just my some of the thoughts I have when I see people talk about price/performance.
Anyway, back to your post, You did a calculation on one benchmark and claimed that the price/performance of the 1070 and 480 were the same. But one benchmark does not even begin to tell the story of the price/performance ratio. You are also working it out without knowing what the actual performance of the 480 is in said benchmark.
So you might end up been right, but, you can't make any predictions just yet.
Just want to add, that I don't think price/performance ratios work at all across different price tiers. Because the people that buy £400 cards will be different from the people buying £200 cards.
I was hoping it would be an upgrade over my gtx 970 mainly in 1440p, but seems like it might be more of a sidegrade for me personally.
Here at our very own OCUK
£365 blower
https://www.overclockers.co.uk/kfa2...ess-graphics-card-70nsh6dhk6vk-gx-090-kf.html
£375 Aftermarket OC edition
https://www.overclockers.co.uk/kfa2...ddr5-pci-express-graphics-card-gx-091-kf.html
970 g1 1418mhz 1753 mem = 2831 g score
970 g1 1600mhz 2000 mem = 3089 g score
http://www.3dmark.com/3dm/12630609
http://www.3dmark.com/3dm/12630726
Any chance you or somebody else can give the score percentage increases from my stock 7950 to its overclocked score?
I just ran my 7950 at stock 800 core clock with a 1625 memory clock (to match the overclocked memory clock) to see the difference but im kinda rubbish with percentages
Stock 7950 core (800/1625) > http://www.3dmark.com/3dm/12631020 > GPU Score 1132 (Driver - 16.4.2 Crimson)
OC 7950 core (1200/1625) > http://www.3dmark.com/3dm/5257360? > GPU Score 2112 (Driver - 14.501.1003.0)
Only asking about this cuz people are saying the 480 maybe another good clocker like 79xx series..
..then im sure we could get a rough estimate of what a 50% overclock on a 480 could bring, as obviously people around here have nothing else to do until the 29th
I know i know, different arch's etc etc.. but its all in a bit of fun![]()
Price to performance = bang for buck = performance to cost ratio. Whether it's a £600 card or £200, you can work out which will give you more for your money. And as I said previously some people will looked to buy 2 to save money but match performance of a bigger card and it helps you work it if the implication of multi GPU is worth the saving over 1 big card.
I didn't say it is the same, I said nearly. I also said "if was to be true" implying it is not real and we don't know for sure yet.
Just an honest question, were you really expecting a £200 card to challenge a £400 card?
1200/800 = 1.5x base clock speed with 2112/1132= 1.8657x performance.
That sounds too good to be true. A 50% clock speed increase results in a 87% increase to performance?? Maybe the drivers are a factor there.
