- 10 Nov 2006
- Lincolnshire
I know you're trying to be sarcastic with that, but it's entirely uninteresting. Why have you bought 4???
WHY, Kaap?! Beggars belief!
I received my MSI GTX1080 Gaming X from OCUK last thing yesterday - I am sure DPD did it just to see me suffer!
Hope I am OK to post this here, but here's my review of the MSI GTX1080 Gaming X - all of the clocks were left 'out of the box' for this review.
Great service as always from OCUK, thanks guys![]()
Interesting test with the high bandwidth SLI bridge, Actually makes quite a difference over the standard bridge in some titles.
16FPS average difference between a normal bridge and HB bridge in the Division using 2 x 1080's.
28FPS average difference between a normal bridge and HB bridge in Fallout 4 using 2 x 1080's.
Seeing as Nvidia are only making an HB bridge with support for 2 cards that's going to be a good chunk of performance lost for people who bought more than 2 x 1080's when using the old bridges.
[/SPOILER]
well he says at the end of the video that they dont need HB bridge if they have 2 legacy connector that gives the same results on the games you listed.
Don't agree with his figures at all.
I get better scaling in Witcher 3 using 4 TXs for example than he managed using 2 cards. 4 TXs also produce a lot more bandwidth than any 2 way Pascal setup can manage.
I also notice he was not using X99 which means he is alreading limiting himself bandwidth wise on the PCI-E slots which may or may not have been a factor. I have seen reviewers make this mistake when reviewing a pair of 295X2s in quadfire and then wonder why the performance takes a 30% hit.
Maybe you could do some testing with the HB bridge versus the old floppy bridge when you get setup ?![]()
I will do.
I just tried my 980 Ti's in 2 way SLI (Firestrike Ultra) with the rigid 3 way SLI bridge that comes with every motherboard. Yesterday I ran the same setup and clockspeeds with a flexi 2 way SLI bridge and got about 3% better performance than I did today with the rigid bridge.
I will test this out properly when I get some 2 way high bandwidth bridges as they look nice regardless of whether they do anything or not.![]()
Ok got the performance metrics on the side to show in the recording for the user vids section -
Should be a little bit before full res is available.
No need for all of that. Grab Display Driver Uninstaller, run it and follow the instructions for booting into safe mode, tick the box for installing a new GPU and run, when the comp restarts, shut down - remove old GPU, place new GPU in and install latest NVidia drivers![]()
Does Anyone use a Custom fan profile with there 1080's FE edition
if so what do you use
This worked a treat. I'm now up and running. Thanks, Gregster.
I have mine at 28% (lowest) til 50c then I get it straight in at 70% and that keeps me under 80c with a decent clock![]()
