- 8 Jun 2007
Picked up a cheap Cubot Note S and got the reward App again,it's gone nuts sending me surveys now lol.
Are those battery apps useful? My friends use DU Battery Saver but it felt like it had a lot of extra useless fluff. So 2 questions
1. Do they work?
2. If yes, do your recommend anything.
Any must have paid apps?
Got nearly a tenner in google rewards funds to use!
answers all true, maybe I should I lie on them.I can't seem to get the rewards app to work anymore, I had 2 Months of it working, and for the last 3 months I've had 3 surveysanswers all true, maybe I should I lie on them.
1. No
2. See 1
They do have an effect but with modern Android version that have very good memory management they actually end up using more battery than the save. Apps that would normally be sleeping in the background get killed and thus use loads more battery when they need to be started again.
Let Android do it's thing. Have good stats on your battery is always useful if you have bad battery life.
You need to have location settings enabled, it tracks where you've been to give you surveys it thinks it relates to you. So for example if you've been to Tescos, it will ask you how your experience at Tescos has been.
Althought I've not used both, TV Show Favs is usually favoured over SeriesGuide by those that have used bothI love it myself, love the 'To Do' list. Helps me easily keep track of what to watch next.
End of this longer than usual survey I got nothing. But then I know nothing about makeup
I got a survey about what makeup I wear and what it makes me feel. Asked me which brands I knew from a list. I read that if you pretend to be a 30 something female you get more surveys - but I promise I didn'tEnd of this longer than usual survey I got nothing. But then I know nothing about makeup
Had the same survey yesterday, very odd. Surely Google at least know I'm male, and yes I realise men can wear makeup but this survey was definitely aimed at women. And after 8 questions no reward.
Any reason why? I've only really used SeriesGuide for the past few years and it does everything I can imagine such an app needing to do!
