- 13 Jul 2004
- Stanley Hotel, Colorado
Its faster afaik
The new activation system looks interesting, you can tie the licence to your MS account, this should prevent issues re-activating when upgrading hardware.
Windows 7 looks slick, clean and mostly modern - I can see though that the overly bevelled (especially with default settings) look can be a bit reminiscent of a trend that went out of fashion around 2000 or so.
Anyone who thinks Windows 10 looks better seriously needs their eyes tested - I can see how some might prefer the more serious look but there is a significant lack of polish and overall cohesion with Windows 10 aesthetically.
You can't say Windows 7 looks modern when the clear trend in UI design over the last few years has long since moved away from transparency/translucency, big shiny physical-style buttons and soft edges. The bold, flat look is everywhere now, while the Vista/7 era design is gone.
10 does look better
10 does look better than, faster as well.
MS have a few tools for blocking troublesome updates some of it here https://support.microsoft.com/en-us/kb/3073930 and there is another minitool for it somewhere as well.
Unfortunately though these are only temporary solutions and at some random point in the future when another update arrives you may end up back in the same situation until you jump through the hoops all over again (or you might get lucky and a fixed driver exists as the latest by then).
If i look at windows 7, there are at least 3 options under the the 'device installation' options in advanced settings. Windows 10 has 1. What a backwards step. Not to mention, as has been said, it doesn't even frigging work anymore.
Updated yet another laptop to Windows 10 over the weekend (from Windows 7), and apart from taking a very long time, went perfectly...
I'd also suggest it's running smoother too!
I f there is one good thing about Windows 10 it is giving old hardware a new lease of life.
Because more often then not there's no windows 10 drivers, so you can't upgrade to it.
I'm wondering if I should try for windows 10 again? any long term pros for a reason to do so? (apart from DX12 which I'd probably miss as I'm going for a GTX 1080 soon from over clockers). Also I notice the CPU in 3dmark 11 seems much faster in win7. 10,345 3d11marks, in windows 7 versus about 9,300 (at best) in win 10. is 10 a CPU hog?, or doesn't it like 3dmark 11 too much ([email protected])
Some really ancient hardware for that to be a problem.
Andi.
