 - 3 May 2004
 - Kapitalist Republik of Surrey
I seem to remember you're not very tall are you? This is always going to put you in a slightly compromised position compared to taller riders.I think my TT position still needs some work!
[image]
I'm thinking of moving the saddle back a bit and maybe a tiny bit higher. Unfortunately, I don't think I can reduce my stack height any further unless I replaced the entire cockpit.
However, compare your position to Quintana:
	-His bars place his arms probably about 40mm lower than yours. Quite a big difference.
-He's a bit further back on the bike overall (and looks more comfortable as a result). Both saddle and elbow position are further back than yours. His elbows are slightly more underneath his shoulders than yours are which, I think, will be more comfortable.
-His head is way lower and his back flatter. Your back is a little curved. This might just be natural curvature, but I'd recommend doing some upper and mid back stretches every morning to flatten out the curve. This will straighten out your back on the back on the bike and naturally result in your head dropping.
 Christ!
 Weather Underground is my new toy by the way, give it a look, they have local weather stations from people all over the shop and you can see historical/forecast weather data to your hearts content. Addictive wee tool, the last thing us data lovers need! Have fun
