- 14 Aug 2008
- North Sea
That TSR.2's simply stunning.
I'm about to buy myself an airbrush and compressor... but what other essential bits will I need that I've not considered?
You will need to give good consideration to a respirator to protect your lungs and is possible an extractor as well.
What paints and thinners you going to use?
The rogues gallery Kylo Ren will be the next addition
[/URL][/IMG]![]()
Can anyone recommend a model kit
What I want is an apollo Saturn 5 rocket on its side showing all the stages
So yeah - hi. I've mentioned earlier I'm doing the Deag Falcon and need an airbrush/airbrush kit, but a quick question. I have a Clarke Ranger 35 air compressor:
8 Bar
7 cu ft/min
1.5hp
24 ltr rec
I know it's not exactly a quiet piece of kit, but would this be any good to use as the compressed air side of things to connect an air brush to, or would I be better off getting something like this: http://www.ebay.co.uk/itm/9cc-mavit...826347?hash=item58deb9952b:g:ibcAAOSwOVpXfVCv
If my compressor would be suitable, what stuff would I need. I assume a dual action air brush, but hoses/filters etc?
Many thanks![]()
How much do you want to spend? I wouldn't use that compressor. I would get one more suited to the task.
I'm afraid I'm out. I refuse to recommend any airbrush/compressor kit under £100 as they always turn out to be crap and frustrating, and in extreme cases are capable of ruining your model by coughing and spluttering paint anywhere.
Stick with an Iwata brush mate. The best by a country mile.
Okie dokes, ta for the reply though. I'd really struggle to justify spending more as after this build I suspect it will just get put in a cupboard and forgotten about, as I can never bring myself to sell stuff on, because "I might need that one day"!! ^_^
