I'm not sure that the outcome and the result should necessarily determine which side of the team they support, and also think it's only fair to look at T1 Austin last year.
The facts the driver are faced with at the point they decide to run their oppo wide with the aim of gaining advantage are :- (I'm ignoring the brake issue as it was a known quantity and so is largely irrelevant.
1) There is a hightened chance contact let's call that 50/50
2) If there is contact there is a change you'll come worse off' I'll call that 55/45 because I assume the drivers know the angles that present the strongest parts of their car, but they don't know completely what the oppo car will do
3) If contact does or doesn't occur, you stand the risk of penalties.
So all in all, the action of pushing out wide is highly risky and slim that you will become better off, and nearly entirely impacted by the action by the oppo at this point, and I guess they make their judgment based on their guess on how the oppo will react.
In Austin Ham pushed Rosberg out wide, just as badly as Ros did in Aus, but Rosberg backed out to avoid contact. There're no damage and also no penalty for Ham, Rosberg did the same thing and got damage and a penalty.
I just put it all down to luck really. Austin could've ended up like Austria , and as a result Rosberg might have won the championship, if he'd just held the outside line but turned. Similarly Ros this week could've nicked Ham a puncture or just squeezed him and gone on to win and extend his lead.
My view they are as much racer's as each, but through luck or judgment, Ham seems to manage his "when's" better
